Logic Machine Forum
Widget opening - Printable Version
+--- Forum: Visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9)
+--- Thread: Widget opening (/showthread.php?tid=1020)
Widget opening - miro.suchanek - 02.10.2017
I would like to open a widget#2 from widget#1. But after opening the widget#2 from the previous widget#1, the position of widget#2 is not as defined in settings of widget#2.
What to do, please?
RE: Widget opening - batistacaceres - 01.05.2020
Can I get the widget#1 position, before opening the widget#2, to set the position of the widget#2. I want to position the widget#2 relative to the position of widget#1. Example, In a page I have 18 buttons that call eachone one diferent widget (main_widgets), 18 diferent main_widgets, but I have only one sub_widget that is called from each of one main_widget, and I want to open this sub_widget in a position relative to the main_widget.
best regards
RE: Widget opening - davidchispas - 15.05.2020
(01.05.2020, 11:44)batistacaceres Wrote: Can I get the widget#1 position, before opening the widget#2, to set the position of the widget#2. I want to position the widget#2 relative to the position of widget#1. Example, In a page I have 18 buttons that call eachone one diferent widget (main_widgets), 18 diferent main_widgets, but I have only one sub_widget that is called from each of one main_widget, and I want to open this sub_widget in a position relative to the main_widget.
best regards
Check out this post where it explains how to open a widget from another widget.
https://forum.logicmachine.net/showthread.php?tid=2363&pid=14886#pid14886
To locate the position of the widgets, it is defined in the structure display
