Logic Machine Forum
ETS program other devices -> problem - Printable Version
+--- Thread: ETS program other devices -> problem (/showthread.php?tid=115)
ETS program other devices -> problem - gjniewenhuijse - 28.10.2015
I used a LM4 to program other devices with ETS4 (latest version).
That works great except programming the Hager TYF646T, i get random errors. Programming the same device with an Jung usb connection device it works great.
How to solve this?
RE: ETS program other devices -> problem - rocfusion - 01.12.2015
One thing you could try is to set the Line Address of the LM4 to be same line address as the initial line address of the bus. ie.. the ETS project file contains modules using line 1.1 then take a free address on 1.1
Thanks,
Roger
RE: ETS program other devices -> problem - gjniewenhuijse - 01.12.2015
(01.12.2015, 09:22)rocfusion Wrote: Hi,
Thanks,
Roger
already done.
only programming this module goes wrong, other modules works great.
