Unused Processes - Printable Version +- Logic Machine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Unused Processes (/showthread.php?tid=1338) |
Unused Processes - rocfusion - 16.04.2018 Hi, In a typical installation, I won't be using the Dali, 1-wire, bacnet and modbus parts of the LM. Is there a way to remove \ disable these components and make this permanent? The reason I ask because I saw with the Processes app that these modules were using a combined CPU usage of 10%. Surely the LM would be more efficient if we could eliminate this overhead. Thanks, Roger RE: Unused Processes - admin - 16.04.2018 You can uninstall genohm-scada-dali and similar packages from System config > System > Packages. Keep in mind that firmware upgrade will revert them back. RE: Unused Processes - rocfusion - 16.04.2018 (16.04.2018, 06:30)admin Wrote: You can uninstall genohm-scada-dali and similar packages from System config > System > Packages. Keep in mind that firmware upgrade will revert them back. Thank you, works good. |
