Custom slider position and design in visualization - Printable Version +- Logic Machine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Custom slider position and design in visualization (/showthread.php?tid=1355) |
Custom slider position and design in visualization - Jayce - 25.04.2018 Hello once again, Is there any way to make it so after I click on object (lightbulb) in the visualization the slider menu appears in the very bottom-right corner? Also if yes, how do I customize the pop-up slider box or the slider itself? Thanks in advance. RE: Custom slider position and design in visualization - Daniel - 25.04.2018 Hi with popover elements we can't use Additional class but you can change position for all of the sliders like that in Custom CSS Code: .popover.control.control-slider-h.slider-h.show{ BR RE: Custom slider position and design in visualization - Jayce - 25.04.2018 works fine, thank you. |
