Logic Machine Forum
Log all bus traffic - Printable Version
+--- Thread: Log all bus traffic (/showthread.php?tid=273)
Log all bus traffic - gjniewenhuijse - 12.04.2016
I like to log all the bus traffic to my mysql database.
How to do this with on a resource frendly way?
RE: Log all bus traffic - edgars - 15.04.2016
for now you can mark all objects with Log check-box and use this example to export CSV once hour/day to external server:
http://openrb.com/example-export-last-hour-csv-object-log-file-to-external-ftp-server-from-lm2/
In the future, we will make a real-time example for exporting this data.
RE: Log all bus traffic - gjniewenhuijse - 19.04.2016
maybe something like this?
But how to show the datahex in readable format?
And is it possible to add a general handler, also for groupreads etc?
if not client then
  require('genohm-scada.eibdgm')
  -- handle group writes
  function eventhandler(event)
    log(event) -- later send this to mysql
    --log(knxdatatype.decode(event.datahex,?))
  -- knx connection
  client = eibdgm:new({ timeout = 1 })
  client:sethandler('groupwrite', eventhandler)
  -- start-up time
  sec, usec = os.microtime()
-- handle knx
client:step()
RE: Log all bus traffic - admin - 20.04.2016
Something like this, though it will not work on older FW where grp.all function is not implemented.
if not client then
  objects = grp.all()
  datatypes = {}
  for _, object in ipairs(objects) do
    datatypes[ object.id ] = object.datatype
  function writehandler(event)
    local dpt = datatypes[ event.dstraw ]
    if dpt then
      local value = knxdatatype.decode(event.datahex, dpt)
  function readhandler(event)
    log(event)
  client:sethandler('groupwrite', writehandler)
  client:sethandler('groupresponse', writehandler)
  client:sethandler('groupread', readhandler)
-- handle knx
client:step()
RE: Log all bus traffic - Ruslan - 20.04.2016
May be modify script for support sending to SYSLOG collector?
RE: Log all bus traffic - Ruslan - 26.04.2016
My simple variant for sending all data to SYSLOG server
In User Libraries need create function syslog:
function syslog(message)
 require('socket')
 local client = socket.udp()
 if client then
   client:sendto(message, '192.168.19.254', 514)
   client:close()
After this markup all objects with tag "All"
Create new event-based script "Send all messages to SYSLOG" for tag "All"
name = grp.alias(event.dst)
-- Fix Group name for empty values
if (name == nil or name == '') then
 name = "Noname"
value = '"'..name..'" '..event.src..' '..event.dst..' '..event.type..' '..knxdatatype.decode(event.datahex, grp.find(event.dst).datatype)..' 0x'..event.datahex
syslog(value)
Sample of log:
2016-04-26T22:52:34.084297+03:00 192.168.16.200 "Wind speed (m/s)" 1.0.1 5/0/6 groupwrite 2.6 0x0104
2016-04-26T22:52:39.817766+03:00 192.168.16.200 "Wind speed (m/s)" 1.0.1 5/0/6 groupwrite 4.5 0x01C2
2016-04-26T22:52:42.632619+03:00 192.168.16.200 "Wind speed (m/s)" 1.0.1 5/0/6 groupwrite 2.7 0x010E
2016-04-26T22:52:45.231188+03:00 192.168.16.200 "Wind speed (m/s)" 1.0.1 5/0/6 groupwrite 3.3 0x014A
2016-04-26T22:52:50.097556+03:00 192.168.16.200 "Wind speed (m/s)" 1.0.1 5/0/6 groupwrite 1.6 0x00A0
2016-04-26T22:52:51.595747+03:00 192.168.16.200 "Noname" 1.3.2 2/2/3 groupwrite 21.4 0x0C2E
2016-04-26T22:52:57.809525+03:00 192.168.16.200 "Temp in room 37" 1.3.22 2/1/24 groupwrite 24.02 0x0CB1
