Logic Machine Forum
export of select objects and associated scripts - Printable Version
+--- Thread: export of select objects and associated scripts (/showthread.php?tid=290)
export of select objects and associated scripts - rocfusion - 04.05.2016
It would be great when we can have some kind of selective import\export function.  For each installation I will always provide similar functionality.  ie I create 100+ virtual scene objects.  When I could export these objects with their group addresses \ tags \ associated scripts and choose which resident scripts to export as a single package it would save sooo much time setting up a LM.
Thanks,
Roger
RE: export of select objects and associated scripts - Erwin van der Zwart - 04.05.2016
Hi Roger,
Why don't you set-up your basics and make a back-up.
Each new project you start by loading your basics back-up and
you have what you just described..
RE: export of select objects and associated scripts - rocfusion - 04.05.2016
(04.05.2016, 18:22)Erwin van der Zwart Wrote: Hi Roger,
I know and I do that.  I find that this would be useful to have a selective import\export.
Thanks,
Roger
RE: export of select objects and associated scripts - admin - 05.05.2016
There is selective import/export for user libraries in new FW. You can wrap your scripts in a function so it can be easily re-used later on.
