Logic Machine Forum
Audio visu? - Printable Version
+--- Forum: Visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9)
+--- Thread: Audio visu? (/showthread.php?tid=340)
Audio visu? - zoltan - 09.07.2016
I need to process audio source selection and playlist management on the touch screen (model/manufacturer not selected yet, cca. 5"). Can I use LM for that purpose?
What is the recommended way to show the name of song playing, radio station name etc. ?
One more question - is there a good looking 4-5" touch panel that can show LM pages?
RE: Audio visu? - admin - 11.07.2016
It depends on what device you are going to use for audio part. If it has some kind of networked API then of course you can create a visualization for LM.
Most touch screens are either cheap and poor quality or very expensive. Have you considered using a smartphone or a tablet instead?
RE: Audio visu? - zoltan - 11.07.2016
(11.07.2016, 12:15)admin Wrote: It depends on what device you are going to use for audio part. If it has some kind of networked API then of course you can create a visualization for LM.
The audio part will most probably be a "farm" of Sonos networked amps (total 15 pcs), one for each room.
I am actively searching (as the available time allows) for a wall mounted tablet, but still nothing good enough. I'm aware that most KNX touch screens are limited and expensive, that's why I'd better like a tablet solution.
Another question arised in the meantime - is it possible to lock the tablet to a single screen on LM? As an example, if I have one screen for each room, can I create 15 of them and lock the tablet to see just its own page?
RE: Audio visu? - Habib - 11.07.2016
You can realize them with different user logins. Each of them can get its own visu page.
RE: Audio visu? - Erwin van der Zwart - 11.07.2016
Hi Zoltan,
You can also create 15 plans and disable the swipe option in general configuration. (otherwise you can swipe between all pages)
Use for each panel a direct URL to the page and then you can bypass the user accounts and avoid the mandatory login when using users.
Like: http://192.168.0.10/scada-vis/#1 for panel 1, http://192.168.0.10/scada-vis/#2 for panel 2 etcetera.
If you don't create navigation buttons then the correct page is always showed.
RE: Audio visu? - zoltan - 12.07.2016
That's an elegant solution!
I was thinking how to solve the autologin with multiple users, but it will inevitable ask for password one day.
Now I just need to find a good wall mounted tablet.
