grp.getvalue() returned value - Printable Version
+--- Thread: grp.getvalue() returned value (/showthread.php?tid=3535)
grp.getvalue() returned value - Kapudan - 31.08.2021
Hi all,
here a very simple question.
What type of data does grp.getvalue() return?
I didn't understand why this code works
    variable  = grp.getvalue('1/1/1')
    if (variable == true) then...
while this not
    if (variable == 1) then ...
1/1/1 is defined on LM as 01.001 Switch
RE: grp.getvalue() returned value - admin - 31.08.2021
For 01.X types it returns a Boolean value (true/false). In Lua true does not equal 1.
RE: grp.getvalue() returned value - Kapudan - 31.08.2021
For the future... where can I find such informations to avoid similar silly questions? :-)
That's what the reference manual says:
"Returns value for the given alias or nil when object cannot be found."
This is more of a Lua language thing. As described in the manual:
Equality (==) first compares the type of its operands. If the types are different, then the result is false (https://www.lua.org/manual/5.1/manual.html#2.5.2)
This is what happens if you try to compare true or false to 1.
Ok, sorry for my unclear question.
What I meant was: where can I find the information that grp.getvalues() method returns a boolean value (true/false) if the reference manual only says "Returns value for the given alias or nil when object cannot be found."?
The value type depends on the datatype. In most cases it will be a number but can also be a Boolean, string or table. You can use log(value) to see what the function returns.
