200 users - Printable Version +- Logic Machine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: 200 users (/showthread.php?tid=4120) |
200 users - Alberto.ricof - 29.06.2022 Good morning, I have to do a project that requires to register 200 different users. At the logic level it won't be very complicated, I calculate that it will take about 210 display pages... No modbus, no bacnet, only a few KNX elements (6 or 7). Would it be possible to do this project with a SL ? A few hardwares ago I saw that a maximum of 50 users was recommended... Thank you very much! Regards, Alberto R. RE: 200 users - admin - 29.06.2022 This mostly depends on the number of active users at any time and the number of telegrams per second. If the project is not big then I suppose it should handle 200 users in total. RE: 200 users - Alberto.ricof - 29.06.2022 (29.06.2022, 12:07)admin Wrote: This mostly depends on the number of active users at any time and the number of telegrams per second. If the project is not big then I suppose it should handle 200 users in total. I will try then, as the traffic will be very very small. Thank you very much!!! Alberto R. |
