Logic Machine Forum
Integration with 2N doorphone - Printable Version
+--- Thread: Integration with 2N doorphone (/showthread.php?tid=485)
Integration with 2N doorphone - buuuudzik - 05.12.2016
maybe do you know if there is a possibility to connect LM with 2N doorphone with video+audio(RTSP) exchange?
In the manual I have such information that for such communication I must send RTSP commands:
rtsp://doorphone_IP/h264_stream
rtsp://doorphone_IP/mpeg_stream
rtsp://doorphone_IP/mjpeg_stream
Is it possible via LM now?
RE: Integration with 2N doorphone - admin - 07.12.2016
Unfortunately, RTSP is not supported by any browser natively, so it's not possible to display it in the visualization directly.
RE: Integration with 2N doorphone - buuuudzik - 08.12.2016
This commands works very nice for camera image streaming:
http://doorphone_IP/enu/cameraWxH.jpg?fps=N
WxH - WIDTHxHEIGHT (160X120, 320X240, 640X480, 176x144, 322x272, 352x288 and 1280x960 but ONLY FOR Mpix cameras)
N - FPS (e.g. 1, 5 or 25)
And also I am using the button for opening the doors and garage doors and switching light.
RE: Integration with 2N doorphone - Domoticatorino - 08.12.2016
Do you use http commands to open the door or switch lights?
Yes, this is based on the library from Schneider:
AN036_Room_Control_and_Door_Entry_Solution_interoperability_v1.0
But unfortunately in this library there isn't any integration with doorphone image via Spacelynk so I must prepare this by myself. From licensing side my client bought only license for "Enhanced integration".
