BACnet connection fail - Printable Version +- Logic Machine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: BACnet connection fail (/showthread.php?tid=5238) |
BACnet connection fail - JulianFlorez - 10.02.2024 Hello, I need help, I have an LM5 on a network with the following parameters: IP address: 143.3.123.8 Subnet mask: 255.255.255.224 Default gateway: 143.3.123.1 When I try to connect with BACnet software such as BDT (BACnet Discovery Tools), the LM5 is not discovered. If I try the same connection with another IP address (private segment and 24-bit subnet mask), BACnet is discovered without any problem. I think the problem is the public IP address, but I don't know if the problem is with the BACnet protocol or the LM5 firmware. Regards. |
