Group address import - Printable Version +- Logic Machine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Group address import (/showthread.php?tid=5249) |
Group address import - Bergman - 16.02.2024 Hi, Is there a way to import GA-addresses + datatype in csv-format or xml? Im using esf today on bigger projects where i don't want every GA in the LM(5). But each time we expand a project I then have to edit the esf-file since that contains all GA's. Or any quicker workaround? RE: Group address import - Daniel - 16.02.2024 There is no partial import option but you can use filter and mass delete to quickly remove what is not needed. RE: Group address import - Bergman - 16.02.2024 Feature request RE: Group address import - Erwin van der Zwart - 18.02.2024 In that case i would opt for a setting “Overwrite existing objects during import” on esf and knxproj import RE: Group address import - admin - 19.02.2024 "Update existing objects" option is already added. |
