CPU charge... - Printable Version +- Logic Machine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: CPU charge... (/showthread.php?tid=5339) |
CPU charge... - SigmaTec - 04.04.2024 Hi, one of my HW 2 Schneider Electric indicate as "CPU/IO : 4.81 5.2 4.1 - Memory 20%" and it is quite slow. Are these values normal or it is a problem ? - 480 objects - 1 cylclic script (15s) - few plans - some JS - ..etc... Good end of day. Thank's in advance for your answer. RE: CPU charge... - Daniel - 04.04.2024 The values are very much not normal, CPU I/O should be below 1. Install Process app to see what is consuming so much. RE: CPU charge... - SigmaTec - 04.04.2024 I don't know this ! How to intall this App ? RE: CPU charge... - Daniel - 04.04.2024 On homepage in top right corner there is a shopping basket, click on it and you will go to app store where you will find Processes app. Install it open and drop screenshot of what you see. RE: CPU charge... - SigmaTec - 04.04.2024 I found that it is this cyclic script (15s) which increases the CPU load from <1 to 5...6... !!! Code: obj_surv_generale = "20/1/20" RE: CPU charge... - Daniel - 04.04.2024 Use OR gate from this example. https://kb.logicmachine.net/scripting/logic-functions-central-statuses/ |
