Logic Machine Forum
iframe and compression - Printable Version
+--- Forum: Visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9)
+--- Thread: iframe and compression (/showthread.php?tid=5374)
iframe and compression - efredlund@gmail.com - 19.04.2024
Hello!
We are linking multiple SL to a master SL trough url frame in the visualization. But I have a problem that the frame looks blury and not sharp. Looks like the image is compressed.
The resolution in the frame is exact the same as the system that it shows. I tried with different resolutions and different web-browsers but get the same result.
If i put an icon over the frame in the master SL, this icon will get blurry as vel.
Is there any way to make the frame pixel-perfect?
RE: iframe and compression - admin - 19.04.2024
Try changing "Usermode view" to "Center plans, limit size" in Utilities > Vis.configuration on the device where the iframe contents is coming from. Have you tried this on a different device/browser?
