Allert Manager
Hello
In the alert manager, how many alarms can be seen, in the logicmachine I have more alarms than those visible in the alert manager, is there a maximum number that can be displayed, can it be changed?
As far as i know there is no limit, other then the alert log size in the general configuration of the controller.
@Admin: I use the localbus WS to fetch the alerts, is there any limitation build-in into the websocket?
Did you disabled the ''Only respond on valid scripts" in the Alert Settings?
Or selecteded all sources where the alert is generated from like "system" and "scriptname" of the script that triggert the alert?
