Rewrite by tag
Hi, is it possible to get values from multiple group addresses by tag, and write back the same values to the group address?
I suppose you want to write back the same values to bus for certain tagged objects periodically. If so create a scheduled script and change the tag name as needed:
objects = grp.tag('my_tag_name')
  object:write(object.value)
(24.09.2021, 07:07)admin Wrote: I suppose you want to write back the same values to bus for certain tagged objects periodically. If so create a scheduled script and change the tag name as needed:
TNX Smile
Is it possible to only rewrite value 3 if the value is 3?
Use this:
  if object.value == 3 then
