Alert manager localization
Hello, there is a small problem with alert managerunfortunatelly i can't change language of alert manager interface, but the local law demand, that interface shoul be in the local language. How to can do it?
Alert manager only has built-in localization in Dutch. Adding other translations is not possible without modifying the app source code.
If you only need to display alerts/events then there's an alternative solution that can be easily customized: https://forum.logicmachine.net/showthread.php?tid=350
