Threads: 39
I would like to log some system parameters such as cpu load, system temperature, memory, network activity, KNX bus activity, etc.
So far I have only been able to figure out cpu load (cat /proc/loadavg) and memory (free).
How can I get the other system parameters?
Threads: 39
Thanks for this.
Where can I find info on temperature? I can't find it in the standard places. From time to time I have temperature warnings so I would like to keep track of this.
Threads: 102
How about KNX BUS load? Is there this value available in LM?
Thank you.
Threads: 41
In next FW release there will be a function called knxlib.getstats() which will return the numbe of IP and TP telegrams sent/received. Total bus load can be calculated from these values.
Threads: 6
This also include grp.update and is not part of the busload, combined with the multiple triggered items within the time period it's not a trustfull methode..
I would wait for next FW where new knx.lib function will be available..
