Art-Net DMX
(23.05.2018, 09:49)sjfp Wrote:
(23.05.2018, 08:35)admin Wrote: Resident script, sleep time = 0. Might require some change to work with C-BUS objects.
if not client then
 ip = '192.168.2.43'
 mapping = { '1/1/1', '1/1/2', '1/1/3', '2/1/1', '2/1/2', '2/1/3' }
 universe = 1
 physical = 0
 udpsock = require('socket').udp()
 addrtoid = {}
 values = {}
 for id, addr in ipairs(mapping) do
   obj = grp.find(addr)
   addrtoid[ addr ] = id
   if obj then
     value = obj.value or 0
     if obj.datatype == dt.scale then
       value = math.floor(value * 2.55)
     value = 0
   values[ id ] = value
 function send()
   local cmd = string.char(
     -- null byte; ARTNET_DMX opcope; protocol version 14, sequence not defined
     0, 0, 0x50, 0, 14, 0,
     -- physical input port from which DMX512 data was input
     bit.band(physical, 0xFF),
     -- 15 bit Port-Address (universe)
     bit.band(universe, 0xFF), bit.rshift(universe, 8),
     -- Length
     bit.rshift(#values, 8), bit.band(#values, 0xFF)
   local req = 'Art-Net' .. cmd .. string.char(unpack(values))
   udpsock:sendto(req, ip, 0x1936)
 function eventhandler(event)
   local id = addrtoid[ event.dst ]
   if id then
     values[ id ] = busdatatype.decode(event.datahex, dt.uint8, event.dstraw)
     send()
 client = require('localbus').new()
 client:sethandler('groupwrite', eventhandler)
 send()
client:step()
Thank you for your assistance. Will have a go when i get back to the office tomorrow evening.
Did you get this solution to work. I have a similar requirement. I have a client with a DMX slider controller that they want to control Cbus controlled lights with. Where did you purchase a art-net interface from?
thanks
Art-Net DMX - by sjfp - 11.05.2018, 12:33
RE: Art-Net DMX - by edgars - 11.05.2018, 13:08
RE: Art-Net DMX - by sjfp - 11.05.2018, 13:20
RE: Art-Net DMX - by admin - 14.05.2018, 06:28
RE: Art-Net DMX - by Erwin van der Zwart - 14.05.2018, 07:53
RE: Art-Net DMX - by sjfp - 14.05.2018, 10:26
RE: Art-Net DMX - by admin - 14.05.2018, 11:02
RE: Art-Net DMX - by Erwin van der Zwart - 14.05.2018, 19:56
RE: Art-Net DMX - by sjfp - 21.05.2018, 17:16
RE: Art-Net DMX - by admin - 15.05.2018, 06:52
RE: Art-Net DMX - by admin - 22.05.2018, 06:00
RE: Art-Net DMX - by sjfp - 22.05.2018, 17:19
RE: Art-Net DMX - by admin - 23.05.2018, 08:35
RE: Art-Net DMX - by sjfp - 23.05.2018, 09:49
RE: Art-Net DMX - by lcrowhurst - 03.02.2020, 03:20
RE: Art-Net DMX - by admin - 03.02.2020, 11:41
RE: Art-Net DMX - by lcrowhurst - 03.02.2020, 12:15
RE: Art-Net DMX - by admin - 03.02.2020, 12:51
RE: Art-Net DMX - by lcrowhurst - 04.02.2020, 12:56
RE: Art-Net DMX - by tomnord - 07.05.2024, 12:54
RE: Art-Net DMX - by admin - 04.02.2020, 13:09
RE: Art-Net DMX - by lcrowhurst - 06.02.2020, 01:21
RE: Art-Net DMX - by lcrowhurst - 07.09.2020, 22:49
RE: Art-Net DMX - by admin - 07.05.2024, 13:07
RE: Art-Net DMX - by tomnord - 07.05.2024, 13:17
RE: Art-Net DMX - by admin - 07.05.2024, 13:20
RE: Art-Net DMX - by tomnord - 07.05.2024, 13:21
RE: Art-Net DMX - by admin - 07.05.2024, 13:42
