Threads: 89
Resident script:23: attempt to call field 'sha512' (a nil value)
stack traceback:
Sha512 is missing in my encdec.
Threads: 41
Threads: 89
(15.07.2019, 13:27)admin Wrote: Send GET request to https://api.cp.dyson.com/v1/provisioning...e/manifest after the first one to get device list. You need to decode the first result using JSON and then pass Accountassword values as Basic auth. See last example in HTTP docs: http://w3.impa.br/~diego/software/luasocket/http.html
Yes i found why there was no return data. I have to use the v2 api for newer devices:
Code: https = require 'ssl.https'
require('json')
socket.http.TIMEOUT = 5
local cUsername = 'xxxx@xxxxxx.com'
local cPassword = 'xxxxxxxx'
-- get session info
local cBody1 = '{"Email":"' .. cUsername .. '","Password":"' .. cPassword ..'"}'
local cReq1 = {}
local cUrl1 = 'https://api.cp.dyson.com/v1/userregistration/authenticate?country=NL'
result1 = https.request({
url = cUrl1,
method = 'POST',
headers = {
['content-length'] = #cBody1,
['content-type'] = 'application/json'
source = ltn12.source.string(cBody1),
sink = ltn12.sink.table(cReq1)
if result1 and cReq1 then
cReq1 = table.concat(cReq1)
cReq1 = json.pdecode(cReq1)
cAccount = nil
cPassword = nil
if cReq1 then
if cReq1.Account and cReq1.Password then
cAccount = cReq1.Account
cPassword = cReq1.Password
--log(cAccount,cPassword)
log(result1)
mime = require("mime")
local cAuth = "Basic " .. mime.b64(cAccount..":"..cPassword)
local cReq2 = {}
local cUrl2 = 'https://api.cp.dyson.com/v2/provisioningservice/manifest' -- v2 for new devices
result2, c, h = https.request({
url = cUrl2,
method = 'GET',
headers = {
['authorization'] = cAuth
sink = ltn12.sink.table(cReq2)
--log(result2,c,h)
log(cReq2)
But the next question, how to decode the password to use it in my mqtt client. Original code from https://github.com/CharlesBlonde/libpure...k/utils.py:
Code: def decrypt_password(encrypted_password):
"""Decrypt password.
:param encrypted_password: Encrypted password
key = b'\x01\x02\x03\x04\x05\x06\x07\x08\t\n\x0b\x0c\r\x0e\x0f\x10' \
b'\x11\x12\x13\x14\x15\x16\x17\x18\x19\x1a\x1b\x1c\x1d\x1e\x1f '
init_vector = b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00' \
b'\x00\x00\x00\x00'
cipher = AES.new(key, AES.MODE_CBC, init_vector)
json_password = json.loads(unpad(
cipher.decrypt(base64.b64decode(encrypted_password)).decode('utf-8')))
return json_password["apPasswordHash"]
Threads: 41
Do you have this encrypted password in plain text? It should be encoded with base64. Can you send it via PM so I can test the decoding locally?
Threads: 89
(26.09.2019, 08:07)admin Wrote: Do you have this encrypted password in plain text? It should be encoded with base64. Can you send it via PM so I can test the decoding locally?
send by PM
Threads: 41
Thanks, here's decryption function, data contents is what you sent me via PM.
Code: data = '...'
-- create key
key = {}
for i = 1, 32 do
key[ #key + 1 ] = i
key = string.char(unpack(key))
-- decrypt data
data = require('encdec').base64dec(data)
aes = require('user.aes')
aes_256_cbc, err = aes:new(key, nil, aes.cipher(256, 'cbc'), { iv = string.rep('\0', 16) }, nil, 0)
data = aes_256_cbc:decrypt(data)
-- unpad data
len = string.byte(data, #data) + 1
data = data:sub(1, -len)
-- decode json
data, err = require('json').pdecode(data)
if type(data) == 'table' then
pass = data.apPasswordHash
log(pass)
Use aes.lua from this post: https://forum.logicmachine.net/showthrea...7#pid12807
Save it as user library named aes
Threads: 89
many thanks, connecting with this output works!
Threads: 89
Yes it works, i can switch the Dyson off, with the follow command (code is not perfect, but you can use it as start for yourself):
Code: require('user.nit_dyson')
runCommand(5,CMD_OFF)
My library
Code: --[[
use getDevices('email@email.com','password') to get the encrypted password and fill it in dysons[] so you can use this offline.
-- product types
DYSON_PURE_COOL_LINK_TOUR = '475'
DYSON_PURE_COOL_LINK_DESK = '469'
DYSON_PURE_HOT_COOL_LINK_TOUR = '455'
DYSON_360_EYE = 'N223'
DYSON_PURE_HOT_COOL_2018 = '527' --HP04 Dyson Pure Hot+Cool 2018 (244289-01)
CMD_OFF = '{"fpwr":"OFF"}'
-- all dyson devices
dysons = {} -- room(not used), ip, port(default 1883), type, username/serial, password
dysons[5] = {'Room', '192.168.x.xxx', 1883, DYSON_PURE_HOT_COOL_2018, 'A1B-EU-KNAXXXXX', 'verylongencryptedpasswordfromgetdevices'}
-- get devices from web portal
function getDevices(iPortalUser, iPortalPwd)
require('json')
local cUsername = iPortalUser
local cPassword = iPortalPwd
-- get session info
local cReq1 = {}
url = cUrl1,
method = 'POST',
headers = {
cAccount = nil
cPassword = nil
if cReq1 then
log(result1)
local cReq2 = {}
url = cUrl2,
method = 'GET',
headers = {
--log(result2,c,h)
log(cReq2)
-- decrypt password
function decryptPwd(iPwd)
data = iPwd
-- create key
key = {}
for i = 1, 32 do
key[ #key + 1 ] = i
-- decrypt data
-- unpad data
-- decode json
--log(pass)
return pass
-- run dyson command
function runCommand(IDevice, iCmd)
broker = dysons[IDevice][2]
port = dysons[IDevice][3]
producttype = dysons[IDevice][4]
username = dysons[IDevice][5]
password = dysons[IDevice][6]
-- after this initialization, you'll have to use the hashed password to connect to the fan. The hashed password is a base64 encoded of the sha512 of the password
passwordDec = decryptPwd(password)
topicCmd = producttype .. '/' .. username .. '/command'
mqtt = require('mosquitto')
client = mqtt.new()
client.ON_CONNECT = function(status, rc, err)
if status then
payload = '{"msg":"STATE-SET", "time":"'..os.date("%Y-%m-%dT%H:%M:%SZ")..'", "data":'..iCmd..'}'
client:publish(topicCmd, payload)
client.ON_PUBLISH = function()
client:disconnect()
client:login_set(username, passwordDec)
client:connect(broker, port)
client:loop_forever()
You can also make an event handler like:
broker = '192.168.x.xx'
port = 1883 -- default port is 1883
username = 'A1B-EU-KNAXXXXX' -- device serial
password = 'longpassword'
producttype = DYSON_PURE_HOT_COOL_2018
topic = producttype .. '/' .. username .. '/status/current'
client = mqtt.new()
if status then
log('connect ok')
client:subscribe(topic)
--payload = '{"msg":"STATE-SET", "time":"'..os.date("%Y-%m-%dT%H:%M:%SZ")..'", "data":{"fpwr":"OFF"}}'
--client:publish(topicCmd, payload)
log('connect error', rc, err)
client.ON_MESSAGE = function(mid, topic, data)
log('message', topic, data)
--log('publish')
--client:disconnect()
client.ON_LOG = function()
--log('log')
client.ON_DISCONNECT = function()
--log('disconnect')
Threads: 89
more codes:
Code: CMD_ON = '{"fpwr":"ON"}'
CMD_AUTO_ON = '{"auto":"ON"}'
CMD_AUTO_OFF = '{"auto":"OFF"}'
CMD_NIGHT_ON = '{"nmod":"ON"}'
CMD_NIGHT_OFF = '{"nmod":"OFF"}'
CMD_HEAT_ON = '{"hmod":"HEAT"}'
CMD_HEAT_OFF = '{"hmod":"OFF"}'
-- not sure if its right, but it works
function CMD_HEAT(iTemp) -- integer celcius
return '{"hmax":"'..2932+((iTemp-20)*10)..'"}' --2932=20 2952=22 2982=25 3012=28 enz
Threads: 89
Threads: 41
Threads: 89
20.08.2020, 08:33
(This post was last modified: 20.08.2020, 08:34 by gjniewenhuijse.)
(19.07.2019, 12:28)admin Wrote: Try this one: https://dl.openrb.com/pkg/luaencdec_20180912_mxs.ipk Where to find the latest version for LM 2020.07 RC3 firwmare
and also the latest mosquitto packages?
Threads: 41
You don't need this package, a newer version is already included in RC3
Threads: 89
(20.08.2020, 08:34)admin Wrote: You don't need this package, a newer version is already included in RC3
oops, i overwitten this package, do you have the latest one? with the latest one i received also an error.
So no need for luaencdec_20180912_mxs.ipk and no need for the mosquitto packages?
Threads: 41
You can reinstall the same FW and all packages will be reverted. You also need updated AES library: https://forum.logicmachine.net/showthrea...5#pid17735
Threads: 89
(20.08.2020, 08:42)admin Wrote: You can reinstall the same FW and all packages will be reverted. You also need updated AES library: https://forum.logicmachine.net/showthrea...5#pid17735
thanks, problem solved
Threads: 89
02.10.2021, 08:54
(This post was last modified: 02.10.2021, 08:55 by gjniewenhuijse.)
After upgrading to a LM5 (HW: LM5 Lite + Ext (i.MX6) SW: 20210806) my code doesn't work
in getDevices there's no response from: https://api.cp.dyson.com/v1/userregistra...country=NL
and also the runCommand doesn't nothing.
What goes wrong? do i need to install extra libraries?
Threads: 41
I've tested your code and there's Cloudflare's 1020 "Access Denied" error. I've tried using different user agent headers but the request is still blocked. I'm not sure whether it is possible to access the authentication using a script now. There can also be a location-based blocking. You can try adding the user-agent header after content-type and check yourself:
Code: ['content-type'] = 'application/json',
['user-agent'] = 'Mozilla/5.0',
Threads: 89
(04.10.2021, 06:41)admin Wrote: I've tested your code and there's Cloudflare's 1020 "Access Denied" error. I've tried using different user agent headers but the request is still blocked. I'm not sure whether it is possible to access the authentication using a script now. There can also be a location-based blocking. You can try adding the user-agent header after content-type and check yourself:
I checked this option already but it doesn't work. I see in the Dyson app that you have you enter your emailadres, after that you have to signin with a password and a code send by email. Maybe thats the change?
Another problem is that i can't send message to the Dyson on my local lan with mqtt (with the runCommand function). Any idea why this stops working after the HW en SW upgrade?
Threads: 89
Many thanks to admin to make it working again
Code: --[[
https://www.npmjs.com/package/homebridge-dyson-pure-cool
https://github.com/lukasroegner/homebridge-dyson-pure-cool
9-10-2021
Sniff passwords with an Android phone and the Dyson link app and Netcapture (also sniff SSL traffic).
You receive data like this and fill them inside the dyson devices (theres a X between username/serial and the password):
.MQTT.<paho3949609190773A1B-EU-MKA0000AXn0MYFEYNRMCk7n9nCxW/F3bDFGQuLtBjQy3W4rg46ZqPc0+wkqqSVTdSVXXXXQnxc2NqgbQPABzbCe81xWQ==
local json = require('json')
debug = false
-- product types
CMD_ON = { fpwr = 'ON' }
CMD_OFF = { fpwr = 'OFF' }
CMD_AUTO_ON = { auto = 'ON' }
CMD_AUTO_OFF = { auto = 'OFF' }
CMD_NIGHT_ON = { nmod = 'ON' }
CMD_NIGHT_OFF = { nmod = 'OFF' }
CMD_HEAT_ON = { hmod = 'HEAT' }
CMD_HEAT_OFF = { hmod = 'OFF' }
function CMD_HEAT(iTemp) -- in graden celcius
return ({ hmax = tostring(2932+((iTemp-20)*10)) }) --2912=18 2932=20 2952=22 2982=25 3012=28 enz
dysons[1] = {'Room 1 ', '192.168.0.14', 1883, DYSON_PURE_HOT_COOL_2018, 'A1B-EU-MKA0000A', 'n0MYFEYNRMCk7n9nCxW/F3bDFGQuLtBjQy3W4rg46ZqPc0+wkqqSVTdSVXXXXQnxc2NqgbQPABzbCe81xWQ=='}
-- debug logger
function debugLog(iLog)
if debug then
log(iLog)
-- send data to dyson
function mqsend(ip, username, password, prefix, cmddata)
local function datetime()
return os.date('!%Y-%m-%dT%H:%M:%SZ')
local ts, tu = os.microtime()
local clientid = 'lm-' .. ts .. '-' .. tu
local mq = require('mosquitto').new(clientid)
mq:login_set(username, password)
mq.ON_CONNECT = function(res, ...)
debugLog('mqtt connect status', res, ...)
if res then
local topic = prefix .. '/command'
local cmd = {
f = topic,
time = datetime(),
msg = 'STATE-SET',
data = cmddata,
['mode-reason'] = 'LAPP',
mq:publish(topic, json.encode(cmd), 1)
mq:disconnect()
mq.ON_PUBLISH = function(mid, rc)
debugLog('published', mid, rc)
mq:disconnect()
mq.ON_DISCONNECT = function(...)
debugLog('mqtt disconnect', ...)
mq.ON_LOG = function(...)
debugLog(...)
local res, rc, errno = mq:connect(ip)
if not res then
debugLog('connect failed', rc, errno)
return
-- process mqtt messages
for i = 1, 20 do
local res, err = mq:loop()
if not res then
break
-- receive current dyson state
function mqstatus(ip, username, password, prefix)
local count = 0
local status = {}
log('mqtt connect status', res, ...)
if res then
local cmd = {
time = datetime(),
msg = 'REQUEST-CURRENT-STATE',
mq:subscribe(prefix .. '/status/current')
mq:publish(prefix .. '/command', json.encode(cmd))
mq:disconnect()
mq.ON_MESSAGE = function(rc, topic, payload)
payload = json.pdecode(payload)
if type(payload) ~= 'table' then
return
local data
if payload.msg == 'CURRENT-STATE' then
data = payload['product-state']
elseif payload.msg == 'ENVIRONMENTAL-CURRENT-SENSOR-DATA' then
data = payload['data']
for key, value in pairs(data) do
if value:match('^%d+$') then
value = tonumber(value)
status[ key ] = value
count = count + 1
if count == 2 then
mq:disconnect()
if not res then
return
for i = 1, 20 do
if not res then
break
debugLog(status)
return status
mqsend(
broker,
username,
password,
producttype..'/'..username,
iCmd
-- runCommand(1,CMD_OFF)
-- get dyson command
function getState(IDevice)
return mqstatus(
broker,
username,
password,
-- log(getState(1))
