Threads: 21
I just tried it on LM4 and it works. Can you make a test as fallow. Make a project backup, perform factory reset. Install the app and test again. If it works restore your backup and check again.
It could be that your dongle failed.
Threads: 19
23.06.2021, 11:46
(This post was last modified: 23.06.2021, 11:47 by Bobby.)
Seems like that did the trick. Thanks!
Threads: 58
Any known issues with bacnet and device name sharing after whois-Iam with scada system? I have two LMs that does not allow my scada to create a config file with all objects. Yabe shows everything OK, so we are unsure if the problem lies with the scada or in LM. We create configs from other Bacnet sources without problem, so it is only with LM we see this behaviour.
Threads: 21
(30.06.2021, 08:13)tomnord Wrote: Any known issues with bacnet and device name sharing after whois-Iam with scada system? I have two LMs that does not allow my scada to create a config file with all objects. Yabe shows everything OK, so we are unsure if the problem lies with the scada or in LM. We create configs from other Bacnet sources without problem, so it is only with LM we see this behaviour.
No, nobody reported anything.
Threads: 4
I tried to download the firmware 2021.05 for LM5 lite but the download link is not working, could you check it? I am very interested in testing the zerotier functionality on my LM5 Lite.
Greetings.
Threads: 21
(05.07.2021, 21:51)german.cespedes@ecoelec.cl Wrote: Hello,
Greetings.
The link works fine, try again.
Threads: 67
Hi, I cancelled LM from my zerotier network by mistake and now, according with their knowledge base, re-add it manually.
but I have to provide the "node number".... How I can get it? I gaved a look on the system logs but I can't find it.
Peppe
