Hi!
I am currently working on a project where I have used gauges in the visualization for showing temperature, relative humidity etc. However the gauges does not show in any way in the touch visualization. I have therefore added a regular KNX-object for the temperature to the visualization where I have chosen the icon to be a transparent .SVG. This way I avoid duplicate representation of the temperature in the normal visualization, and I still get a temperature value in the touch visualization. However, this makes it hard to edit the interface since you have to be able to press on a invisible object. Is there a better way to achieve this? Or might it be possible to add functionality so you can get a list over all the object added to the interface, so you can delete them without actually having to press on the icon in the visualization to select them?
