Delete object logs from script
Hi, is there a way to delete all object logs from a script?
Thanks! Smile
Something like below:
db:delete('objectlog', { id > -1 })
db:query('DELETE FROM objectlog')
The istruction returns this error:
Quote:User script:35: attempt to compare number with nil
stack traceback:
User script:35: in main chunk
Use the second code example, the first one is incorrect, though it can be used like this:
db:delete('objectlog')
Thank you!  Smile
(18.05.2017, 07:38)admin Wrote: Use the second code example, the first one is incorrect, though it can be used like this:
Hello Admin
how to delete a specific object address logs?
Best Regards,
Use this:
id = buslib.encodega('1/1/1')
db:delete('objectlog', { address = id })
(26.07.2021, 10:16)admin Wrote: Use this:
Thanks admin
Best Regards,
hello admin
How to delete a specific period for a specific address
regards,
Best Regards,
Like this, you need to specify the min/max log time as UNIX timestamp:
mintime = os.time() - 3600 * 2
maxtime = os.time() - 3600
db:query('DELETE FROM objectlog WHERE address=? AND logtime BETWEEN ? AND ?', id, mintime, maxtime)
(01.09.2021, 09:13)admin Wrote: Like this, you need to specify the min/max log time as UNIX timestamp:
thank you, admin
great
where to learn about these query command?
like if I want it to be depend on value
db:query('DELETE FROM objectlog WHERE value<=0')
doese this work?
Best Regards,
It's more complicated. Value is stored raw format so it has to be decoded before comparison.
obj = grp.find('1/1/1')
rows = db:getall('SELECT * FROM objectlog WHERE address=?', obj.id)
for _, row in ipairs(rows) do
  if row.datahex then
    value = busdatatype.decode(row.datahex, obj.datatype)
    if value <= 0 then
      db:delete('objectlog', { id = row.id })
(01.09.2021, 12:08)admin Wrote: It's more complicated. Value is stored raw format so it has to be decoded before comparison.
  if row.datahex then
    if value <= 0 then
thank you admin
is it easy to make it in general (delete all obj. logs <=0)
Best Regards,
Try this:
rows = db:getall([[
  SELECT ol.id, ol.datahex, o.datatype
  FROM objectlog ol
  JOIN objects o ON ol.address=o.id
  if row.datahex then
    value = busdatatype.decode(row.datahex, row.datatype)
    if type(value) == 'number' and value <= 0 then
(01.09.2021, 12:37)admin Wrote: Try this:
rows = db:getall([[
  FROM objectlog ol
  if row.datahex then
thank you very much
appreciate your help
Best Regards,
