MySQL packages
Hi!
I want to insert data into MySQL database. When I install MySQL packages, I see this error. What is wrong? My version 20210521.
You are installing wrong packages. You can check your CPU type in System config > Upgrade firmware:
[Image: attachment.php?aid=1740]
If it says (i.MX6) then you need these packages: https://dl.openrb.com/lm-21-imx6/pkg/
Otherwise use these: https://dl.openrb.com/lm-21-mxs/pkg/
thank you very much!
