Threads: 21
Can i use instead of the LAN module also the KM2 that has connection to vbus.net also?
Vbus LAN : https://www.resol.de/en/produktdetail/76
Vbus KM2 datalogger : https://www.resol.de/en/produktdetail/209
Threads: 21
(09.03.2021, 11:33)KoBra Wrote: Can i use instead of the LAN module also the KM2 that has connection to vbus.net also?
Nobody that has an answer?
Threads: 41
The examples posted in this thread are for the LAN module
Threads: 21
Dear all, hopefully somebody has a clue.
I have the resol module with script https://openrb.com/logicmachine-as-gatew...s-protocol
but keep getting the reply "* string: VBus modules not available"
Threads: 41
Check that you have three user libraries created: user.luavbus, user.luavbuspacket and user.vbusprofiles
Threads: 21
(03.01.2023, 09:36)admin Wrote: Check that you have three user libraries created: user.luavbus, user.luavbuspacket and user.vbusprofiles Yep they are all installed. incl the fixing of the bug on line 42 as described earlier in the topic.
Threads: 21
(03.01.2023, 11:16)KoBra Wrote: (03.01.2023, 09:36)admin Wrote: Check that you have three user libraries created: user.luavbus, user.luavbuspacket and user.vbusprofiles Yep they are all installed. incl the fixing of the bug on line 42 as described earlier in the topic.
Found this in the error log
Code: Resident script:23: attempt to index global 'vbus' (a nil value)
stack traceback:
I can't find the problem there as i just copy pasted that script
Code: for _, searcher in ipairs(package.searchers or package.loaders) do
name = "luavbus"
local loader = searcher(name)
if type(loader) == 'function' then
package.preload[name] = loader
vbus = require (name)
break
name = "user.luavbus"
break
log_level = WARN
if ( vbus == nil ) then
log ( "VBus modules not available")
vbus.new(nil, TCPIP, "vbus" )
vbus.remote_host = "192.168.0.1"
vbus.remote_port = "7053"
vbus.password = "vbus"
vbus:connect()
-- filter = { srcAddress = 0x7e11, dstAddress = 0x0010 }
-- filter = { command = 0x200 }
packets = vbus:waitData(filter, 30 )
if (packets ~= nil ) then
log( string.format ( "Returned %d packets", #packets ) )
for key, packet in pairs(packets) do
-- print ( string.format ( "Packet: %s", packet ) )
-- print ( packet:profileprint() )
if ( packet.profileData ~= nil) then
for k, data in pairs ( packet.profileData ) do
if ( data.factor < 1 ) then
log( string.format ( "Name %s Value %.02f %s", data.name, data.value, data.unit ) )
log( string.format ( "Name %s Value %d %s", data.name, data.value, data.unit ) )
log( "No packet!!!")
Threads: 41
Post a screenshot of your User libraries tab. Make sure that "auto load library" is disabled for all vbus libraries.
Threads: 21
(05.01.2023, 08:19)admin Wrote: Post a screenshot of your User libraries tab. Make sure that "auto load library" is disabled for all vbus libraries.
auto load library is off for all
Threads: 41
library names for vbus must be all lowercase
Threads: 21
(06.01.2023, 14:16)admin Wrote: library names for vbus must be all lowercase
changed all the scripts to lowercase but no difference:
Log tab: * string: VBus modules not available
Error Log tab: Resident script:23: attempt to index global 'vbus' (a nil value) stack traceback:
Threads: 6
Do you have require('user.vbus') at the start of the scripts that needs to use the user libs?
Threads: 21
(07.01.2023, 19:28)Erwin van der Zwart Wrote: Do you have require('user.vbus') at the start of the scripts that needs to use the user libs?
i changed line 9 in the script below from luavbus to vbus.
name = "luavbus"
break
name = "user.vbus"
break
log_level = WARN
vbus.remote_host = "192.168.0.188"
vbus:connect()
it seems it improved a bit because now the error logs show
Code: User library Vbus:716: bad argument #1 to 'pairs' (table expected, got nil)
stack traceback:
[C]: in function 'pairs'
User library Vbus:716: in function 'readDevicesProfiles'
User library Vbus:233: in function 'waitData'
Threads: 21
(07.01.2023, 22:29)KoBra Wrote: (07.01.2023, 19:28)Erwin van der Zwart Wrote: Do you have require('user.vbus') at the start of the scripts that needs to use the user libs?
name = "luavbus"
break
name = "user.vbus"
break
log_level = WARN
vbus:connect()
stack traceback:
After starting the resident script now i get a different error.
Code: User library Vbus:149: attempt to index field 'socket' (a nil value)
stack traceback:
User library Vbus:149: in function 'connect'
Threads: 41
This error means that the connection failed. Check that the IP address of Vbus device is correct and that you can ping it from LM.
Threads: 21
(09.01.2023, 07:59)admin Wrote: This error means that the connection failed. Check that the IP address of Vbus device is correct and that you can ping it from LM.
It was online but not responsive, now we are back to the previous error. (i should have thought of this ![Angel Angel](https://forum.logicmachine.net/images/smilies/angel.png) )
Threads: 41
Replace the top part of the user.vbus with this. Then restart the resident script via disable/enable. It will produce an error if your user libraries are not named in all lowercase (vbusprofiles and luavbuspacket).
Code: local luavbus = {}
socket = require ("socket")
cjson = require("json")
vbusprofiles = require("user.vbusprofiles")
luavbuspacket = require("user.luavbuspacket")
local SERIAL, TCPIP = 0, 1
Threads: 21
09.01.2023, 08:57
(This post was last modified: 09.01.2023, 08:57 by KoBra.)
(09.01.2023, 08:41)admin Wrote: Replace the top part of the user.vbus with this. Then restart the resident script via disable/enable. It will produce an error if your user libraries are not named in all lowercase (vbusprofiles and luavbuspacket).
The response:
Code: User library vbus:15: module 'user.vbusprofiles' not found:
no field package.preload['user.vbusprofiles']
no file './user/vbusprofiles'
no file 'Library user/vbusprofiles'
no file 'User library vbusprofiles'
no file 'Library user/vbusprofiles.so'
no file 'Library user.so'
stack traceback:
[C]: in function 'require'
User library vbus:15: in main chunk
so i changed name from vbusprofile > vbusprofiles
Code: User library vbus:16: module 'uservbuspacket' not found:
no field package.preload['uservbuspacket']
no file './user/luavbuspacket'
no file 'Library user/luavbuspacket'
no file 'User library luavbuspacket'
no file 'Library user/luavbuspacket.so'
stack traceback:
User library vbus:16: in main chunk
so i changed vbuspacket to luavbuspacket
now the error is:
Code: User library vbus:725: attempt to index global 'cjson' (a boolean value)
stack traceback:
User library vbus:725: in function 'readDevicesProfiles'
User library vbus:240: in function 'waitData'
Threads: 41
You need to remove these lines from the library:
name = "cjson"
cjson = require (name)
break
name = "json"
break
name = "vbusprofiles"
vbusprofiles = require (name)
break
name = "user.vbusprofiles"
break
name = "luavbuspacket"
luavbuspacket = require (name)
break
name = "user.luavbuspacket"
break
Threads: 21
(09.01.2023, 09:29)admin Wrote: You need to remove these lines from the library:
name = "cjson"
break
name = "json"
break
break
break
break
break
now we go to
Code: User library vbus:303: bad argument #3 to 'format' (no value)
stack traceback:
[C]: in function 'format'
User library vbus:303: in function 'packetExtract'
User library vbus:205: in function 'waitData'
