App to display object info
Hello my goal is to make a app to display battery info for all my battery powered devices.
Tags used in the object: battery_chk1 (20 devices) and battery_chk2 (10 devices).
How to make a app that displays the object name, object value, last updated time (order by tag, object name)?
require('apps')
d1 = grp.tag('battery_chk1')
d2 = grp.tag('battery_chk2')
<!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8">
<title>Objects</title>
<link rel="stylesheet" href="/apps/css/bootstrap.css">
<link rel="stylesheet" href="/apps/css/font-awesome.css">
<link rel="stylesheet" href="/apps/css/style.css">
<script src="/apps/js/jquery.js.gz"></script>
<style>
body { padding: 20px; background-color: #fff; }
.navbar { background-color: #eee; }
</style>
</head>
<body>
<div class="navbar navbar-default navbar-fixed-top">
<div class="container-fluid text-center">
<span class="btn btn-default navbar-btn pull-right back"><span class="fa fa-lg fa-times"></span></span>
<span class="btn btn-default navbar-btn pull-left refresh"><span class="fa fa-lg fa-refresh"></span></span>
<span class="navbar-brand">Objects</span>
</div>
</div>
<div class="wrap">
<div class="container">
  <table class="table table-hover">
    <thead>
      <tr>
        <th>Name</th>
        <th>Value</th>
        <th>Date</th>
      </tr>
    </thead>
    <tbody></tbody>
  </table>
</div>
</div>
<script>
$(function() {
  function render(data) {
    // sort data by name
    data.sort(function(a, b) {
      var na = a.name.toLowerCase()
        , nb = b.name.toLowerCase();
      if (na > nb) {
        return 1;
      else if (na < nb) {
        return -1;
      else {
        return 0;
    // show each object name/value/update time
    $.each(data, function(index, item) {
      var trs = $('<tr><td></td><td></td><td></td></tr>').appendTo('tbody')
        , tds = trs.find('td')
        , d = new Date(item.updatetime * 1000);
      $(tds[ 0 ]).text(item.name);
      $(tds[ 1 ]).text(item.value);
      $(tds[ 2 ]).text(d.toString().split(' GMT')[0]);
  render(<?=json.encode(d1)?>);
  render(<?=json.encode(d2)?>);
  $('.refresh').click(function() {
    window.location.reload();
  $('.back').click(function() {
    $(this).find('.fa')
      .removeClass('fa-times')
      .addClass('fa-refresh fa-spin')
    window.location = '/apps/';
</script>
</body>
</html>
(09.10.2017, 12:02)admin Wrote:
require('apps')
<!DOCTYPE html>
<html>
<head>
<style>
</style>
</head>
<body>
</div>
</div>
<div class="wrap">
   <thead>
     <tr>
       <th>Name</th>
       <th>Value</th>
       <th>Date</th>
     </tr>
   </thead>
   <tbody></tbody>
 </table>
</div>
</div>
<script>
$(function() {
     if (na > nb) {
       return 1;
     else if (na < nb) {
       return -1;
     else {
       return 0;
   $(this).find('.fa')
</script>
</body>
</html>
thnks....
It gives: Uncaught SyntaxError: Unexpected token < at:
Which firmware version are you running?
Try this:
render(<? write(json.encode(d1)) ?>);
render(<? write(json.encode(d2)) ?>);
(10.10.2017, 06:11)admin Wrote: Which firmware version are you running?
Try this:
Versie: 20170620
same error:
Are you putting this into .lp file? It must be .lp, .html will not work.
(10.10.2017, 06:26)admin Wrote: Are you putting this into .lp file? It must be .lp, .html will not work.
yes, that works.. Thanks
