24.08.2018, 19:38 (This post was last modified: 24.08.2018, 20:31 by Kai-Roger.)
Hi.
No big deal, but when the temperature values in FB editor reaches 21.4 C, the decimal number count gets very big. Is this normal? See the picture. Next to group 5/2/9 in top left corner.
25.08.2018, 06:49 (This post was last modified: 25.08.2018, 06:50 by Erwin van der Zwart.)
You probably use a 4 byte float object, does the object in configurator object tab shows the same value as in the editor? If yes try to change the object to 2 byte float.
