23.08.2018, 18:27 (This post was last modified: 23.08.2018, 18:34 by XSPA2474KW.)
Dear Erwin
I need your help, because I can't see my IP cameras from HomeLynk. Instead I can monitor through IP cameras when I am connected to LAN, WAN or when I am connected through port forwarding.
Thanks in advance for your help.
And one more question.
As we have discussed I have a HomeLynk 1.1.0 and one IP Router 1.2.0. All are working right, I can control both the 2 lines 1.1 and 1.2 from HomeLynk 1.1.0 when I am on local network or when I am connected to HomeLynk through DNS and a port forwarding 3671.
BUT I can't find the HomeLynk in Bus tab in ETS when I am connected through external wifi.
I configure the interface as:
individual address:1.1.0
Server: name of dynsdns
Port: 3671.
I have tried NAT both checked and unchecked.
No i mean your WAN address from your ISP, now you use DynDNS in the connection but does it work when you enter the external IP of your connection inside the ETS..
it is not working again. I have tried both for HomeLynk and IP Router.
Please see the picture.
