Threads: 161
i've found some good tips for optimizing Lua programs:
https://www.lua.org/gems/sample.pdf
Done is better than perfect
This guide is for standard Lua, where as LM uses LuaJIT which already does many optimizations when running the code.
Threads: 161
FYes, but some of advices are very good also for JIT version E.g. using locals(also using local copy of math.sin when using it in loop and modifying data model. Maybe this is for some advanced users intuitive but for sure for less of users. Also using simple for loop instead of in ipairs when you must optimize your script.
Threads: 4
How can create a window pop-up in the crhome or firefox when one object active?
Please create a separate thread and explain in more detail.
Threads: 3
I need use the goto statement for avoid to execute some commands.
How I can implement it?
Fabio
