Threads: 41
You need to forward UDP port 3671 on your router and use NAT mode in ETS. But from a security point of view it's much better to use VPN.
Threads: 23
12.03.2018, 17:55
(This post was last modified: 12.03.2018, 17:56 by balatis.)
thanks for the answer .i have a problem with telegram. some times send a local telegram my homelynk on it's own as a result to start a/c ,open some lights
have you any ideas why? in the source address write local
thank you ....
Threads: 21
It can't send on its own. Disable all your scripts, sync, reboot and check again. Also check scheduler.
