Threads: 85
a customer of mine has an Iphone 6S and using Safari browser no command is sent on bus.
It is not a problem of user because with the same I can by Android.
What do you suggest?
Threads: 41
Which firmware version are you running and are your using HTTPS?
Threads: 161
11.04.2018, 07:22
(This post was last modified: 11.04.2018, 07:22 by buuuudzik.)
I also saw such situation on Safari with Mosaic + HTTPS.
Done is better than perfect
Threads: 85
Firmware is 20170620 and I use https.
What can I do?
Threads: 21
Apple is blocking websocket connection via https when self signed certificate is used.
Locally use http and remotely use our cloud and https this will work fine.
Threads: 85
Hi Daniel,
with cloud service, do I have to use mosaic or I can connect as https standard?
Threads: 21
If you want to use https then use mosaic cloud.
Threads: 36
(04.05.2018, 16:11)Daniel. Wrote: If you want to use https then use mosaic cloud.
Other solution?
KNX Advanced Partner + Tutor
