Threads: 34
Could you provide some examples/solutions LM with Microsoft Azure?
Your devices are Azure Certified, but I can not understand what the profit is. Can you explain me concept with examples?
Threads: 21
All the Azure applications are custom made based on specific project needs. We have dedicated team which can deliver such application. If you have specific request feel free to contact us and we can discuss implementation.
We will share some examples soon.
In short we can monitor and analyze any type of data and any amount of it. We can generate any report and make calculations based on the data. Some of the common use is predictive control.
Threads: 21
OK some examples:
1. You have multi residential project and want to monitor and predict energy consumption in all these houses. You want to compare each of them and you also want to notify customer of his consumption prediction. In some countries government have subsidies if you reach certain level. All driven by 2020 regulations and in the future one will be even more strict regulations.
2. BREEAM certificate - The amount of data which has to be reported to BREEAM is huge and cloud can easily store all of it and generate proper report when needed.
3. Imagine you have big plant which is supplying hot water to several properties. In conventional installation plant can just produce and hope it is enough. With cloud we can monitor each property and tell the plant what is the demand and we can even predict consumption which will bring extreme amount of savings.
Threads: 0
regards
You can help me with the information required to send data to iot hub de azure. I'm using a logicmachine5 reactor to monitor variables related to electrical energy, I need to send and monitor them in the cloud.
Thank you
Threads: 21
