Threads: 60
Start with an empty interface, create your rooms, now only add custom widgets to the rooms you created. Now browse to the mosaic. All of the rooms are empty. Now add a non custom widget to any room. Browse back to mosaic and you will see all the widget.
Roger
Threads: 21
In did, thanks for discovery.
Threads: 21
(02.05.2019, 07:46)Trond Hoyem Wrote: (13.08.2018, 19:36)rocfusion Wrote: Hi,
Roger
I saw the same on SL with firmware 2.3.0 today. Got quite a fright when no widgets was showing after severals days of adding custom widgets (yes, I should have checked the user interface, but who bother). Luckily, this workaround works, but this should be fixed, right?
This was fixed long time ago at last for Mosaic. Not sure if SE fallowed our update. They work now on Mosaic 3.0 so I guess fix will come together with it.
