Threads: 60
It would be nice when we could move widgets from one room to another. That would save a lot of time.
Thanks,
Roger
Threads: 21
Custom widgets can be saved as json file and restored in the another room. I see no reason to move normal widgets.
Threads: 60
sure the layout of the widget can be saved. you still have to re-assign the group addresses. the point being you save time.
moving, copying is a normal time saving feature available in 99.9% of all apps. there is no reason not to.
Threads: 13
I would like this too, too often I am spending time creating widgets and room/floor arrangements to then get to the conclusion that the customer likes it different
Result delete and restart...
Time is money
Threads: 44
It takes about 15 minutes to set up a whole house with Touch visu. I really don’t see the problem...
Threads: 60
creating a visu in 15 minutes has no bearing on this. Create a custom widget connected to +10 objects, now populate that across 20 rooms.
