Threads: 40
Is it possible to have inverted horizontal slider as an option just like the vertical?
Thank you in advance
Threads: 21
What is the reason behind this?
Threads: 40
I have a curtain that opens on the right side, the slider is bounded to curtain position and i need it to respond as the curtain drive. + or right arrow should lower the value.
Threads: 21
For now use another object to convert it like this
grp.write('1/1/1', 100 + event.getvalue()*(-100)/100)
Change 100 to 255 if you use unsigned object not scale.
Threads: 40
I didn't want to go that way, i prefer to invert the actuator drive if there is no other clean option.
