Threads: 161
22.09.2018, 17:58
(This post was last modified: 22.09.2018, 18:00 by buuuudzik.)
Use "Vis. configuration" which is at the bottom left of editor view and change "Usermode view" to e.g. "Center plans, enable auto-sizing"
Done is better than perfect
Threads: 161
In very, very past I have such issue and it was because of this setting also because the plan resolution was different than background image resolution. So it is not normal and it must be possible to solve it
Threads: 161
Take a photo of settings of this plan e.g. plan resolution and backgrounds.
Threads: 21
Try 'Usermode auto-size upscaling:' You probably have small resolution of visu where your screen has higher.
Threads: 7
But no matter what setting is or is not set, this is a bug, no ?
When in visu modes, both are aligned as they should be (both objects have the same v pos value!). In "edit" mode, the items are not aligned.
Am I the only one aligning labels and values ?????
Threads: 41
Can you provide a backup to test this? It can be fixed using a couple of Custom CSS rules.
Threads: 41
Add this to Custom CSS. This will fix this issue for all elements at once, you don't need to add additional classes.
