Threads: 10
In Mosaic 2, I have issue to use CO2/Humidity/Temp widget.
CO2 seems to list only 2 bytes floating objects while I am saving CO2 to a 2 bytes unsigned integer.
What object types are allowed and which one is recommended for CO2 ?
Threads: 21
Yes it is DPT type 9 so you have to convert this data via script or try to make custom widget in widget creator.
Threads: 99
in Mosaic 3.0 you will be able to make this widget yourself and use general Number field which can support any data type you want.
Threads: 21
(18.10.2018, 20:42)Matt Wrote: (18.10.2018, 07:08)Daniel. Wrote: Hi
Thanks Daniel,
Is it a best practice to use type 9 to store CO2? I can change the type of the object but type 9 seems less accurate than type 7 or 8. I don't think sensors (for example netatmo) will leverage floating point. ppm value seems an integer for me.
KNX DPT 9.008 - Air quality, we have native support for KNX not natamo
Threads: 10
Thanks, I updated my objects (and netatmo script) to be type 9, it would be great to add 9.008 in the type list of logicmachine.
Threads: 6
21.10.2018, 08:24
(This post was last modified: 21.10.2018, 08:40 by Erwin van der Zwart.)
Why should 9.008 be added? It’s just a 2 byte float with a different unit (ppm) that you can set yourself on the 9 object (suffix).
