Threads: 21
What for do you need 100Mb/s? KNX is 9.6Kb/s
Threads: 21
You will not see any difference. Visu is always saved in cache of browser and then it is only data exchange which are KNX objects.
If you buy new LM5 then you could see some difference as HW is much faster then the very old LM2.
Threads: 21
(19.10.2018, 09:18)gtsamis Wrote: (19.10.2018, 09:12)Daniel. Wrote: You will not see any difference. Visu is always saved in cache of browser and then it is only data exchange which are KNX objects.
Actually i do see a lot of difference. Even in lan when lm is locked at 100Mbps the visu page loads at no time, when locked at 10Mbps same visu page loads at about 3-5sec.
hm... in normal (modern) browser it should not matter, let Admin came back from holiday, he may say something.
Threads: 41
This looks like a hardware issue of some sort. Can you try another switch/router if possible?
Threads: 60
Just try changing your network cable to the LM.
Threads: 40
11.12.2018, 13:50
(This post was last modified: 11.12.2018, 14:10 by gtsamis.)
Hi again,
Seems that changing cable and switch just solved the problem temporally.
The LM still locks at 10Mbps most of the times plus it starts logging Transmitter Error(send 0 receive 1) and KNX/TP Connected.
Is there anything else i could try ?
Thank you in advance
George
Threads: 41
Since this is a hardware issue the only proper solution is to replace the device. Please contact us via e-mail.
