Threads: 37
I have a customer who's got one strange value in a trend (very high).
How can I edit this value ?
Is see in backup files called T1.trend...
but can't edit it. Before I just had to change bad value in it, but now looks like it a special codage.
Can you help me ?
SE ECO EXPERT
Threads: 21
Let me guess, you are using counter trend. If counter is used and value is smaller then previous then such strange high value will happen. You should use counter with negative delta which allow negative values in calculation.
Threads: 41
Can you upload backup somewhere and send link via PM? I'll see what can be done.
Threads: 37
08.11.2018, 14:44
(This post was last modified: 08.11.2018, 15:03 by domotiqa.)
(08.11.2018, 14:41)admin Wrote: Can you upload backup somewhere and send link via PM? I'll see what can be done.
the site is not connected to internet ! I will have to make it when I will be there !
You don't have procedure for that ? Before I just edited these files, now the format is unknow !
MAybe it was with pspad, I use notepad+ now !
SE ECO EXPERT
Threads: 41
Trend format has not been changed from day 1. It uses RRD as a storage engine.
Threads: 37
11.11.2018, 10:19
(This post was last modified: 11.11.2018, 11:01 by domotiqa.)
I try rrdtool dump xxx.rrd > xxxx.xml
rrdtool restore --force-overwrite xxx.xml xxx.rrd
Why not using during backup the conversion to xml. Would be easyer to change value in backup files!
SE ECO EXPERT
Threads: 41
XML uses too much space and restore procedure is not very fast.
Threads: 4
hello,
I am having a bad recording with counter as well. Is there some easy way to edit a data point in trends (to repair the data)?
thanks!
