Threads: 44
I’m increasingly reusing different scripts in projects and as some may know, it might be a tedious effort to create the different scripts and group addresses on each project.
I’m just wondering if there is a plan to create a sort of script.create function in the software in the near term?
Threads: 21
Why would you want this?
Threads: 102
I think the idea is clear. If you make a new visualisation for block of N buildings where all houses are the same but group addresses differs (because you use a numbering scheme) then you want to create only one visualisation and copy it N times. This tool is heavily missing at LM. What I suggested (unsuccessfully) was a set of scripts which parse the whole project to (many) Excel sheets. A system implementator can bulk modify what he wants and re-create the project back by another script.
Threads: 44
16.01.2019, 06:28
(This post was last modified: 16.01.2019, 06:29 by FatMax.)
Thomas use case makes sense, but for me personally it would allow me to build one install script for repetitive functions that depends on event and resident/scheduled scripts and different group addresses that needs to be created.
It would also allow me to install functions remotely from a server and perhaps update scripts with a script.insert command.
I’m sure many users would benefit from this sort of functionality.
Threads: 39
I like the idea of it, I'm sure it would be very useful.
Threads: 41
Here's an example of how to create script from another script:
Code: data = {
-- either event, resident or scheduled
type = 'event',
-- unique script name
name = 'my script',
-- 1 = active, 0 = inactive
active = 1,
-- event script: group address or tag
-- resident script: sleep time in seconds (0..60)
-- scheduled script: execution date/time in CRON format
params = '1/1/1',
-- set to 1 to enable "execute on read" for event scripts
-- not used for resident and scheduled scripts
subparams = 0,
-- script Lua code
script = 'log(123)',
-- optional script category
category = '',
-- optional script description
description = '',
-- check for duplicate script with the same name
exists = script.get(data.name)
if not exists then
db:insert('scripting', data)
data.id = db:getlastautoid()
script.save(data, true)
script.reloadsingle(data)
Threads: 44
18.01.2019, 07:31
(This post was last modified: 18.01.2019, 07:32 by FatMax.)
Thanks!
Threads: 6
(17.01.2019, 12:59)admin Wrote: Here's an example of how to create script from another script:
Code: data = {
type = 'event',
name = 'my script',
active = 1,
params = '1/1/1',
subparams = 0,
-- script Lua code
category = '',
description = '',
if not exists then
Hey guys,
how can i insert a three or four line code there ?
Threads: 41
Like this:
Code: str = [[multi
line
string]]
Threads: 6
(19.04.2020, 09:27)admin Wrote: Like this:
Code: str = [[multi
line
string]]
Thanks Admin.
Threads: 10
Code: data = {
type = 'event',
name = 'my script',
active = 1,
params = '1/1/1',
subparams = 0,
-- script Lua code
category = '',
description = '',
if not exists then
I am using this for for 'autosetup' LM with a startup (init) script and it has been very useful.
Is there any simular way to add functions to 'common functions' (or overwrite the file) ?
Threads: 41
Use this:
Code: script.checkuserlib(common_functions_code)
script.reload()
Threads: 10
(18.08.2022, 06:35)admin Wrote: Use this:
script.reload()
Works great, thanks!
Threads: 44
Onto the next question;
Is it also possible to create user libraries with a script?
Threads: 41
You can use webrequest library in latest firmware to emulate web UI requests:
Code: webrequest = require('webrequest')
-- user library name
libname = 'test'
-- create user library
params = {
data = {
id = 'user.' .. libname,
name = libname,
type = 'user',
source = true, -- keep source
load = false, -- autoload
description = 'test description',
res, err = webrequest('scripting', 'save', params)
log(res, err)
-- save user library source
params = {
data = {
scriptonly = true,
script = [[
log('test user library')
log(res, err)
Threads: 44
15.09.2023, 12:46
(This post was last modified: 15.09.2023, 13:14 by FatMax.)
Thank you again for the great help. Is this web request library documented anywhere? I would like to also create new Modbus-profiles and this would be very helpful.
I guess search is my friend: https://forum.logicmachine.net/showthread.php?tid=4425
