Threads: 19
04.10.2023, 20:38
(This post was last modified: 04.10.2023, 20:38 by manos@dynamitec.)
Hello Admin,
I can understand that but we have a LM5Lp2 and using it on various sites as a logger when required. It is not that it is running for very long periods. I just want to overcome the 50k data points limit. In the projects we have (not logging everything of course), I would guess that 50K telegrams will be enough for one day. If the LM is logging for 7-15 days then this file will be 15 time written or so. When installed on a new site for example we can delete all files from the FTP server and start over with the logging.
Is this possible to do?
Regards,
Threads: 41
See this example: https://openrb.com/example-export-last-h...-from-lm2/
It has both local file and remote FTP options.
Threads: 19
16.01.2024, 11:59
(This post was last modified: 16.01.2024, 12:03 by manos@dynamitec.)
(05.10.2023, 06:52)admin Wrote: See this example: https://openrb.com/example-export-last-h...-from-lm2/
Hello Admin,
I have applied the solution from the example on the link, although unfortunately I just noticed that not all fields are included on the csv file. I would like to export all data that can be seen on the object logs utility. For the moment only timestamp, address, name and value is included in the csv export...
I am using the following script:
Code: --ftp file
ftpfile = string.format('/home/ftp/%s.csv', os.date('%Y-%m-%d_%H-%M'))
-- get past 12 hours data (43200 seconds)
logtime = os.time() - 12 * 60 * 60
-- list of objects by id
objects = {}
-- objects with logging enabled
query = 'SELECT address, datatype, name FROM objects WHERE disablelog=0'
for _, object in ipairs(db:getall(query)) do
objects[ tonumber(object.address) ] = {
datatype = tonumber(object.datatype),
name = tostring(object.name or ''),
-- csv buffer
buffer = { '"date","address","name","value"' }
-- get object logs
query = 'SELECT src, address, datahex, logtime, eventtype FROM objectlog WHERE logtime >= ? ORDER BY id DESC'
for _, row in ipairs(db:getall(query, logtime)) do
object = objects[ tonumber(row.address) ]
-- found matching object and event type is group write
if object and row.eventtype == 'write' then
datatype = object.datatype
-- check that object datatype is set
if datatype then
-- decode data
data = knxdatatype.decode(row.datahex, datatype)
-- remove null chars from char/string datatype
if datatype == dt.char or datatype == dt.string then
data = data:gsub('%z+', '')
-- date to DD.MM.YYYY
elseif datatype == dt.date then
data = string.format('%.2d.%.2d.%.2d', data.day, data.month, data.year)
-- time to HH:MM:SS
elseif datatype == dt.time then
data = string.format('%.2d:%.2d:%.2d', data.hour, data.minute, data.second)
data = ''
-- format csv row
logdate = os.date('%Y.%m.%d %H:%M:%S', row.logtime)
csv = string.format('%q,%q,%q,%q', logdate, knxlib.decodega(row.address), object.name, tostring(data))
-- add to buffer
table.insert(buffer, csv)
-- upload to ftp only when there's data in buffer
if #buffer > 1 then
data = table.concat(buffer, '\r\n')
io.writefile(ftpfile, data)
How can this be modified to include the type (read/write) and source address fields?
Kind Regards,
Threads: 41
Threads: 37
(17.01.2022, 08:17)admin Wrote: Escaping of the "to" address was missing.
Here's a rewritten script with clearer structure. You only need to modify the to/settings/subject at the to top of the script. SSL settings do not matter anymore because newer SSL library automatically negotiates the highest supported SSL/TLS version between server/client.
Code: to = 'to@example.com'
settings = {
from = 'sender@example.com',
-- smtp username
user = 'sender@example.com',
-- smtp password
password = '12345678',
-- smtp server
server = 'smtp.gmail.com',
-- smtp server port
port = 465,
-- enable ssl, required for gmail smtp
secure = 'sslv23',
subject = 'CSV logs'
logtime = os.time() - 60 * 60 -- last hour (3600 seconds)
buffer = {'"date","address","name","value"'}
query = [[
SELECT o.id, o.datatype, o.name, ol.datahex, ol.logtime, ol.eventtype
FROM objectlog ol
JOIN objects o ON ol.address=o.id
WHERE ol.logtime >= ?
ORDER BY ol.id DESC
if row.datatype and row.eventtype == 'write' then
data = grp.decodevalue(row.datahex, row.datatype)
buffer[ #buffer + 1 ] = string.format('%q,%q,%q,%q',
logdate, knxlib.decodega(row.id), row.name, tostring(data))
csv = table.concat(buffer, '\r\n')
smtp = require('socket.smtp')
mime = require('mime')
ltn12 = require('ltn12')
function escape(v)
return '<' .. tostring(v) .. '>'
to = escape(to)
msgt = {
headers = {
to = to,
['content-type'] = 'text/csv',
['content-disposition'] = 'attachment; filename="logs.csv"',
['content-transfer-encoding'] = 'BASE64',
subject = subject,
body = ltn12.source.chain(
ltn12.source.string(csv),
ltn12.filter.chain(mime.encode('base64'), mime.wrap('base64'))
settings.source = smtp.message(msgt)
settings.from = escape(settings.from)
settings.rcpt = { to }
res, err = smtp.send(settings)
log(res, err)
Hi, thanks for the script,
is there an easy way to separate in different csv file the log object and send them in one email?
SE ECO EXPERT
Threads: 37
20.02.2024, 11:49
(This post was last modified: 20.02.2024, 12:07 by domotiqa.)
I test it but I think the smtp output of my customer is blocked (result 1, nil) for the log. I will try on my test server
Code: smtp = require('socket.smtp')
to = 'xxx@gmail.com'
message='export log'
logtime = os.time() - 60 * 60--*24*7 -- last hour (3600 seconds)
-------------- cherche les cpt
query = [[
SELECT ol2.name
FROM objects ol2
WHERE ol2.disablelog = 0
csv={}
nombre=0
nom={}
for _, objectlog in ipairs(db:getall(query, logtime)) do
nombre=nombre+1
nom[nombre]=objectlog.name
--buffer = {'"date","address","name","value"'}
buffer = {'"date","name","value"'}
query2 = [[
FROM objectlog ol
WHERE (ol.logtime >= ?) ORDER BY ol.id DESC
for _, row in ipairs(db:getall(query2, logtime)) do
if row.datatype and row.eventtype == 'write' and row.name == nom[nombre] then
buffer[ #buffer + 1 ] = string.format('%q,%q,%q',
--logdate, knxlib.decodega(row.id), row.name, tostring(data))
logdate, string.split(row.name,'-')[5], tostring(data))
csv[nombre] = table.concat(buffer, '\r\n')
end --pour chaque object ayant log
attachement = {}
nombre=0
for _, nomCpt in ipairs(nom) do
nombre=nombre+1
-- create file
table.insert(attachement, {filename=nomCpt .. '.csv', filedata=csv[nombre], mimetype='text/csv'})
mailattach(to, subject, message, attachement)
and function in common
Code: --********************************
-- send an e-mail with attachments
function mailattach(to, subject, message, files)
local settings = {
from = 'notification@xxx.com',
-- smtp username
user = 'notification@xxx.com',
-- smtp password
password = 'xxx',
-- smtp server
server = 'xxx.net',
--server = 'xxxx.net',
-- smtp server port
port = 465,
--port = 587,
secure = 'sslv23',
--secure = 'tlsv1_2',
-- ssl0.ovh.net sur port 465
-- ns0.ovh.net sur ports 25, 5025, 587, enfin tout ce que j'essaye...
local smtp = require('socket.smtp')
if type(to) ~= 'table' then
to = { to }
for index, email in ipairs(to) do
to[ index ] = '<' .. tostring(email) .. '>'
-- escape double quotes in file name
for _, object in ipairs(table) do
--files[_].filename = files[_].filename:gsub('"', '\\"')
-- fixup from field
local from = '<' .. tostring(settings.from) .. '>'
-- message headers and body
email = {headers = {}, body = {}}
email.headers = {
to = table.concat(to, ', '),
subject = subject,
['From'] = from,
--['Content-type'] = 'text/html; charset=utf-8',
email.body[1] = { headers = { ['Content-Type'] = 'text/html; charset=utf-8', }, body = mime.eol(0, message) }
-- adding attachements
for _, object in ipairs(files) do
email.body[_+1] = {
headers = { ['Content-Type'] = files[_].mimetype or 'text/plain', ['Content-Disposition'] = 'attachment; filename="' .. files[_].filename ..'"', ['Content-Transfer-Encoding'] = 'BASE64', },
body = ltn12.source.chain( ltn12.source.string(files[_].filedata), ltn12.filter.chain(mime.encode('base64'), mime.wrap() ) )
settings.source = smtp.message(email)
settings.from = from
settings.rcpt = to
return smtp.send(settings)
SE ECO EXPERT
