Threads: 5
I have been trying to pull some data like power consumption and prices. Limited Lua/json scripting skills have brought it to a stop, can anybody help`?
API Guide https://developer.tibber.com/docs/guides/calling-api
Best regards, Jørn.
Threads: 41
Change token and data query as needed:
Code: https = require('ssl.https')
json = require('json')
ltn12 = require('ltn12')
token = 'd1007ead2dc84a2b82f0de19451c5fb22112f7ae11d19bf2bedb224a003ff74a'
data = json.encode({
query = '{viewer {homes {currentSubscription {priceInfo {current {total energy tax startsAt }}}}}}'
tbl = {}
res, code = https.request({
url = 'https://api.tibber.com/v1-beta/gql',
method = 'POST',
headers = {
['authorization'] = 'Bearer ' .. token,
['content-length'] = #data,
source = ltn12.source.string(data),
sink = ltn12.sink.table(tbl),
if res and code == 200 then
resp = table.concat(tbl)
resp = json.pdecode(resp)
log(resp)
log(res, code)
Threads: 5
Superb! But i get "nesting too deep" before all data is retrieved, is this issue on Tibber side or LM `?
Code: * table:
[data]
* table:
[viewer]
* table:
[homes]
* table:
[1]
* table:
[currentSubscription]
* table:
[priceInfo]
* table:
nesting too deep
Best regards, Jørn.
Threads: 41
There's a limit of how deep the table can be for log() function, try this:
Code: log(resp.data.viewer.homes)
Threads: 9
How de we retrieve a value from table within table here, and write this to a group address?
grp.write('32/1/16', 'tbl[1][1][1][1][4][1]')?
kind regards
thomas
Threads: 41
Depends, can you show log output for this table?
Threads: 9
Threads: 41
Code: homes = resp.data.viewer.homes
info = homes[ 1 ].currentSubscription.priceInfo.current
log(info.energy)
log(info.tax)
log(info.total)
Threads: 9
That worked :-) Thank you again :-)
Threads: 12
I've been testing this for a while, and get all the readings from viewer, homes, currentSubscriptions and so on.
But the liveMeasurement I can't really figure out.
Have anyone got this to work?
Eirik
Threads: 12
Very interesting. Anyone who knows how to also integrate the current Power consumption and data from the TIBBER PULSE ? Would be great With some help.
Schneider Wiser (homeLynk), Power Tags, DALI, Multitouch Pro, Panasonic Heating pump, Flexit balansed ventilation, HUE integration, Lemus Speaker system. Tibber integration.
Threads: 12
01.03.2020, 22:26
(This post was last modified: 11.01.2023, 18:13 by stemic01.)
I would really like to get the live consumption "REAL TIME SUBSCRIPTION" data for visualization and making trends.
https://developer.tibber.com/Explorer (Demo token / Real time Consumption)
Would be deeply greatfull if any of you LUA specialists were able to help me retrieve this data and for example Write it to a Group address I could call in my Dashboard Interface.
Here is the "code" from the Tibber API. How to get this into something usefull in LUA?
subscription{
liveMeasurement(homeId:"xxxxxxxxxxxxxxxxxxxxx"){
timestamp
power
accumulatedConsumption
accumulatedCost
currency
minPower
averagePower
maxPower
Threads: 12
I try to boost this thread again. Any takers?
Threads: 41
Use this websocket client library: https://forum.logicmachine.net/showthrea...23#pid7823
Create a user library named websocket and add this line after 'Connection: Upgrade', (line 289):
Code: 'Sec-WebSocket-Protocol: graphql-ws',
Example resident script, sleep time = 0, change token and homeId as needed:
Code: if not client then
ws = require('user.websocket')
query = [[
subscription{
liveMeasurement(homeId:"c70dcbe5-4485-4821-933d-a8a86452737b"){
timestamp
power
accumulatedCost
currency
minPower
averagePower
maxPower
url = 'wss://api.tibber.com/v1-beta/gql/subscriptions'
client, err = ws.client('sync', 10)
res, err = client:connect(url)
if res then
client:send(json.encode({
type = 'connection_init',
payload = 'token=' .. token,
id = 1,
type = 'start',
payload = {
query = query
log('connection failed: ' .. tostring(err))
client:close()
client = nil
data, _, _, opcode, err = client:receive()
if data then
data = json.pdecode(data)
if data then
log(data)
log('receive failed: ' .. tostring(err))
client:close()
client = nil
Threads: 5
03.04.2020, 18:49
(This post was last modified: 03.04.2020, 18:50 by Jørn.)
Works great But, how to pull data from the table to i.e. to a grp.write`?
Best regards, Jørn.
Threads: 6
04.04.2020, 07:23
(This post was last modified: 04.04.2020, 07:23 by Erwin van der Zwart.)
At line 51 (log data) your need to add your code, look at the data table and select the value you want to send to KNX, i don't know the content of the data fields but something like:
Code: -- log(data)
grp.checkwrite('1/1/1', data.yoursubfield1)
grp.checkwrite('1/1/2', data.yoursubfield2)
Threads: 5
(04.04.2020, 07:23)Erwin van der Zwart Wrote: Hi,
Code: -- log(data)
I've tried different combinations of this with no luck. I.e. data.power is nil.
The "data" table looks like this
Code: Tibber websocket 04.04.2020 15:53:26
* table:
["type"]
* string: data
["payload"]
* table:
["data"]
* table:
["liveMeasurement"]
* table:
["timestamp"]
* string: 2020-04-04T15:53:26+02:00
["accumulatedCost"]
* number: 5.133123
["maxPower"]
* number: 8190
["power"]
* number: 1555
["currency"]
* string: NOK
["averagePower"]
* number: 4301.6
["accumulatedConsumption"]
* number: 68.357767
["minPower"]
* number: 1269
["id"]
* number: 1
Best regards, Jørn.
Threads: 41
Try data.payload.data.liveMeasurement.power
Threads: 5
04.04.2020, 14:05
(This post was last modified: 04.04.2020, 14:12 by Jørn.)
That worked ;o) But sometimes report error attempt to index field 'payload' (a nil value) stack traceback:
why would this be`?
Best regards, Jørn.
Threads: 6
05.04.2020, 00:10
(This post was last modified: 05.04.2020, 00:11 by Erwin van der Zwart.)
You should check if the table content is valid before drilling down deeper...
Code: if data then
if data.payload then
if data.payload.power then
grp.checkwrite('1/1/1’, data.payload.power)
