Threads: 9
Is there anybody that has done an integration with Mitsubishi`s cloud portal MELCloud through api?
I found this french guy that has reversed engineered this and created a python script to communicate with it.
http://mgeek.fr/blog/un-peu-de-reverse-e...r-melcloud
From web searches I have found plugins created for Home Assistant and Domoticz based on this.
It would be awsome to have my heating pump also visualized on the HomeLynk.
kind regards
thomas
Threads: 41
Can you send cloud login/password via PM so I can provide a working example?
Threads: 9
Threads: 41
Here's a working example, it will log all devices from your account.
Code: email = 'test@test.com'
password = '123456'
https = require('ssl.https')
json = require('json')
ltn12 = require('ltn12')
function encodepost(t)
local res = {}
local esc = require('socket.url').escape
for k, v in pairs(t) do
res[ #res + 1 ] = esc(k) .. '=' .. esc(v)
return table.concat(res, '&')
function login(email, password)
local url = 'https://app.melcloud.com/Mitsubishi.Wifi.Client/Login/ClientLogin'
local data = encodepost({
AppVersion = '1.9.3.0',
Language = '7',
CaptchaChallenge = '',
CaptchaResponse = '',
Persist = 'true',
Email = email,
Password = password,
local res, code = https.request(url, data)
if res then
resp = json.pdecode(res)
if type(resp) ~= 'table' then
return nil, 'failed to decode reply data'
elseif resp.ErrorId ~= json.null then
return nil, 'cloud login failed'
return resp.LoginData.ContextKey
return nil, 'login request failed'
function getdevices(key)
local url = 'https://app.melcloud.com/Mitsubishi.Wifi.Client/User/ListDevices'
local tbl = {}
local res, code = https.request({
url = url,
headers = {
['X-MitsContextKey'] = key
sink = ltn12.sink.table(tbl),
if res then
local data = table.concat(tbl)
return json.pdecode(data)
return nil, 'get devices request failed'
key, err = login(email, password)
if key then
items, err = getdevices(key)
if items then
for _, item in ipairs(items) do
local devs = item.Structure.Devices
for _, dev in ipairs(devs) do
log(dev)
log(err)
log(err)
Threads: 9
Nice! Thank you very much :-)
Threads: 0
(12.08.2019, 11:54)thomasoppida Wrote: Nice! Thank you very much :-) Hello,
this topic is a bit older but I hope it can be active again and maybe someone can help ...
I am using ioBroker and Melcloud. There is an adapter for homebridge which I am using actually. But I think that it could be done with objects and status. I am serching for a solution to make states which can be read from a json like I do it already for my homepilot or the controme heating system. But I have no idea because I am new to this ...
Maybe here is someone knowing the iobroker and knows maybe how to handle the script in this topic correctly. Or maybe it is not possible ...
I think the probelm is to get the JSON - For controme I have this javascript - but I also have already the json api available, which I do not have for melcloud -Example für the kitchen and the sensors:
Code: const request = require('request');
const link_kueche = 'http://192.168.1.12/get/json/v1/1/temps/1/';
// Datenpunkte erzeugen
//Küche
createState('Controme.kueche.frt_temp', 0, {type: "number", unit: '°C'});
createState('Controme.kueche.rl_temp', 0, {type: "number", unit: '°C'});
createState('Controme.kueche.frt_akt', 0, {type: "string", unit: ''});
createState('Controme.kueche.rl_akt', 0, {type: "string", unit: ''});
createState('Controme.kueche.solltemperatur', 0, {type: "number", unit: '°C'});
function controme_kueche() {
request(link_kueche, function(error,response, body) {
if(error) log('Fehler request: ' + error, 'error');
else if(body.indexOf('html') == -1) {
log(body);
var sensoren = JSON.parse(body)[0].sensoren;
var solltemp = JSON.parse(body)[0];
var rl_temp = sensoren[0].wert;
setState('Controme.kueche.rl_temp', Math.round(10*rl_temp)/10, true);
var frt_temp = sensoren[1].wert.Temperatur;
setState('Controme.kueche.frt_temp', Math.round(10*frt_temp)/10, true);
var rl_akt = sensoren[0].letzte_uebertragung;
setState('Controme.kueche.rl_akt', rl_akt, true);
var frt_akt = sensoren[1].letzte_uebertragung;
setState('Controme.kueche.frt_akt', frt_akt, true);
var soll = solltemp.solltemperatur;
setState('Controme.kueche.solltemperatur', Math.round(10*soll)/10, true);
function alledaten() {
controme_kueche();
controme_schlafzimmer();
controme_wohnzimmer();
controme_abstellkammer();
controme_badezimmer();
controme_flur();
controme_arbeitszimmer();
controme_esszimmer();
controme_hkv();
controme_vsensor1();
schedule('*/1 * * * *', alledaten); // alle 15 Minuten
So the question is - is someone using iobroker and melcloud and has done something like that or has anybody any idea how to do it ? I would like to learn out of this but I have no idea and I am a bloody newbe .
Any ideas ... Thanks so far ...
Best regards,
Marc
Threads: 41
Start by checking HTTP communication. This script will send a GET request and log the result (change IP as needed):
Code: url = 'http://192.168.1.12/get/json/v1/1/temps/1/'
http = require('socket.http')
require('json')
http.TIMEOUT = 5
data, err = http.request(url)
log(data, err)
Threads: 0
Hey, thanks for your reply ... :-)
It seems I can not use it in iobroker as a Javascript. I get errors on the log:
javascript.0 2020-02-05 18:36:42.446 error (13885) at Script.runInContext (vm.js:133:20)
javascript.0 2020-02-05 18:36:42.445 error (13885) at script.js.Mitsubishi.Skript_1:5:14
javascript.0 2020-02-05 18:36:42.445 error (13885) TypeError: Cannot set property 'TIMEOUT' of undefined
javascript.0 2020-02-05 18:36:42.445 error (13885) ^
javascript.0 2020-02-05 18:36:42.445 error (13885) http.TIMEOUT = 5
javascript.0 2020-02-05 18:36:42.444 error (13885) script.js.Mitsubishi.Skript_1: script.js.Mitsubishi.Skript_1:5
javascript.0 2020-02-05 18:36:42.443 error (13885) at Script.runInContext (vm.js:133:20)
javascript.0 2020-02-05 18:36:42.442 error (13885) at script.js.Mitsubishi.Skript_1:4:1
javascript.0 2020-02-05 18:36:42.442 error (13885) script.js.Mitsubishi.Skript_1: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../json'
javascript.0 2020-02-05 18:36:42.439 error (13885) at Script.runInContext (vm.js:133:20)
javascript.0 2020-02-05 18:36:42.439 error (13885) at script.js.Mitsubishi.Skript_1:3:8
javascript.0 2020-02-05 18:36:42.439 error (13885) script.js.Mitsubishi.Skript_1: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../socket.http'
Maybe I need to run the script elswhere but not in iobroker ? If yes, how and where ...
For URL I need to use the melcloud, I guess. But before I need to logon there ... see the script in topic #4 - I tried this also in iobroker but has errors in log also ... seems not to be JAVA.
If possible I should login with Java, then find possible devices and the create the datapoints ...
Best regards,
Marc
Threads: 41
My example is in Lua for LM
