Threads: 8
Hey guys
which kind of switching-aktor for enocean i can take and which profile i have to set. I just want an on / off channel.
Threads: 41
Simple relays are controlled via push buttons, you need to use one of Rocker Switch profiles.
Threads: 8
I tried the Eltako FMS61NP-230V and TF61L-230V
both dosnt work.
sometimes the FMS61NP worked, but only every 5 times sending
Threads: 21
Check with manufacture which profile do they use. I couldn't see it anywhere.
Threads: 6
What range do you have between the controller and the Enocean device? Sounds like a connection issue due to poor signal..
Have you tested it in close range of the controller?
Threads: 8
yes, I thought it was too far.
That's why I bought a repeater (Eltako FRP61-230).
At this is to see if signals come (red LED).
There is nothing to see, so I think the USB stick is broken.
Today I tried it with a NodOn module, that does not work either.
All signals send the USB stick does not work, only received works. I have a PTM-215 button, and it works great (same distance).
I will order a new USB stick.
Is there maybe something to look out for?
Threads: 6
You could test your USB stick with Dolphin from Enocean.
This way you know if your stick is broken or you might made a mistake in the settings.
Threads: 8
it works.
The transmitting power from the USB is just too weak.
next to each other on the table It works, but 1 floor in between is no longer possible
Threads: 6
That is the downside of Enocean, and one if the many reasons that we prefer Zigbee (:
Threads: 8
Zigbee!? is it also work for HL?
Threads: 21
Yes, but it will be new device not usb extension.
Threads: 57
Hi Tee_
I would like to give my opinion on this Post to tell you that what works best on/off with EnOcean & Logicmachine are the products whose profile is D05-00-01. The profile is an important concept in enOcean: I mainly use it to retrieve alerts (open door, alarms ...)
Have a nice day !
