Threads: 161
02.11.2019, 06:23
(This post was last modified: 02.11.2019, 06:24 by buuuudzik.)
Hi I'm searching a way to get info about request method in .lp file.
Probably it is in variable __ngx_req but how can I deal with userdata objects?
Done is better than perfect
Threads: 6
Can you explain what you try to achieve?
Threads: 161
Of course, I want prepare a file config.lp which would handle the GET and POST requests based on request method. As simple as that
Threads: 41
Use ngx.var.request_method
Threads: 161
02.11.2019, 08:41
(This post was last modified: 02.11.2019, 09:32 by buuuudzik.)
Perfect. Thank you all
How can I set header for response?
