Threads: 37
IS it planned to develop Obix gateway like you did with Bacnet ?
What do you think about it.
SE ECO EXPERT
Threads: 99
by our information people are not using Obix too widely. You can realize same tasks on web services.
Maybe you can provide your arguments why it is worth to add support of Obix?
Thanks!
Threads: 37
no it was just a question, because I readed this:
http://www.knx.org/fileadmin/downloads/0...ebsite.pdf
And in this doc, Obix looks more open... It was just in order to have your though
SE ECO EXPERT
Threads: 6
(03.03.2016, 10:00)domotiqa Wrote: no it was just a question, because I readed this:
Hi Domotiqa,
Here are 2 functions i use to communicate with our SmartStruxure Lite controller with oBIX. Maybe you can use it.
-- function to get data from mpm
function get_data_from_mpm(mpm_settings,object,item)
local url = "http://" .. mpm_settings.username .. ":" .. mpm_settings.password .. "@" .. mpm_settings.ip .. "/obix/network/" .. mpm_settings.node .. "/DEV" .. mpm_settings.instance .. "/" .. object .. "/" .. item
local b, c, h = mpm.request(url)
local value = b:match([[val="(.-)"]])
local value = tonumber(value)
return value
-- function to post data to mpm
function post_data_to_mpm(mpm_settings,object,item,value)
local url = "http://" .. mpm_settings.username .. ":" .. mpm_settings.password .. "@" .. mpm_settings.ip .. "/obix/network/" .. mpm_settings.node .. "/DEV" .. mpm_settings.instance .. "/" .. object .. "/" .. item .. "/"
local reqBody = [[<intl val="]] .. value .. [["/>]]
local headers = {["Content-Type"] = "text/xml", ["Content-Length"] = #reqBody}
local respTable = {}
local returnList = {client = {}, code = {}, headers = {}, status = {}}
local source=ltn12.source.string(reqBody)
local sink=ltn12.sink.table(respTable)
local result = mpm.request{url=url, method="POST", source=source, sink=sink, headers=headers}
return result
Erwin van der Zwart
Threads: 37
cool !!
Thank for the info
SE ECO EXPERT
Threads: 6
(05.03.2016, 14:00)domotiqa Wrote: cool !!
Thank for the info
You will need to add this: local mpm = require('socket.http') before using the mpm.request. The request is made to a basic auhtentication server.
I have a mpm.digest libary if you need digest login.
Have fun with it (;
Erwin van der Zwart
Threads: 99
good job, Erwin!
Threads: 99
thanks to Erwin van der Zwart, I am glad to post a complete oBIX module for integration with SmartStruxure Lite including Digest Authentication user library.
1. oBIX to MPM with digest - use as event or resident based script
Code: --======================================================================================================
--******************************** MPM OBIX CONNECTION WITH DIGEST SUPPORT ***************************--
--************************ Version 1.0 Created by Erwin van der Zwart 08-01-2016 *********************--
require('user.mpm_functions') -- See this library for mpm number(s) with valid credentials and IP settings
-- Select MPM (mpm number, autoresolve node id)
mpm_settings = get_mpm_settings(1, true)
-- get data from mpm (mpm settings, object, item)
result = get_data_from_mpm(mpm_settings, "AV61", "Present_Value")
log(result)
-- post data to mpm (mpm number, object, item, value)
post_data_to_mpm(mpm_settings, "AV61", "Present_Value", 111)
result = get_data_from_mpm(mpm_settings, "AV62", "Present_Value")
log(result)
post_data_to_mpm(mpm_settings, "AV62", "Present_Value", 222)
2. user.mpm_functions for oBIX to MPM with digest - user libary 1
--******************************* MPM FUNCTION LIBRARY WITH DIGEST SUPPORT ***************************--
local mpm = require "user.mpm_digest"
function get_mpm_settings(mpm_number,autoresolve)
function resolve_node()
local url = "http://" .. mpm_username .. ":" .. mpm_password .. "@" .. mpm_ip
-- resolve node id automaticly (if not found we will use above but that one can be wrong)
if h then
mpm_node_id = string.sub(h.server, 1, 7)
return mpm_node_id
--**************************************** Put here your MPM settings ********************************--
if mpm_number == 1 then -- Select MPM 1
mpm_ip = '192.168.10.205'
mpm_username = 'admin'
mpm_password = 'Schneider'
mpm_node_id = 'N004EAB'
mpm_instance = 100
elseif mpm_number == 2 then -- Select MPM 2
mpm_ip = '192.168.10.206'
mpm_node_id = 'N005EAB'
mpm_instance = 150
elseif mpm_number == 3 then -- Select MPM 3
mpm_ip = '192.168.10.207'
mpm_node_id = 'N006EAB'
mpm_instance = 200
else -- Select MPM with default settings (node ID is resolved automaticly)
mpm_ip = '10.50.80.3'
mpm_password = 'admin'
mpm_node_id = 'N000000'
autoresolve = true
mpm_instance = 100
--******************************************** End of MPM settings ***********************************--
MPM_Settings = {ip = mpm_ip, username = mpm_username, password = mpm_password, node = mpm_node_id, instance = mpm_instance}
if autoresolve then
MPM_Settings.node = resolve_node()
return MPM_Settings
return value
return result
3. user.mpm_digest for oBIX to MPM with digest - user libary 2
--******************************* MPM DIGEST LIBRARY FOR DIGEST MD5 SUPPORT **************************--
local md5sum = nil
local md5 = {}
local char, byte, format, rep, sub =
string.char, string.byte, string.format, string.rep, string.sub
local bit_or, bit_and, bit_not, bit_xor, bit_rshift, bit_lshift
local ok, bit = pcall(require, 'bit')
if ok then
bit_or, bit_and, bit_not, bit_xor, bit_rshift, bit_lshift = bit.bor, bit.band, bit.bnot, bit.bxor, bit.rshift, bit.lshift
ok, bit = pcall(require, 'bit32')
if ok then
bit_not = bit.bnot
local tobit = function(n)
return n <= 0x7fffffff and n or -(bit_not(n) + 1)
local normalize = function(f)
return function(a,b) return tobit(f(tobit(a), tobit(b))) end
bit_or, bit_and, bit_xor = normalize(bit.bor), normalize(bit.band), normalize(bit.bxor)
bit_rshift, bit_lshift = normalize(bit.rshift), normalize(bit.lshift)
local function tbl2number(tbl)
local result = 0
local power = 1
for i = 1, #tbl do
result = result + tbl[i] * power
power = power * 2
return result
local function expand(t1, t2)
local big, small = t1, t2
if(#big < #small) then
big, small = small, big
for i = #small + 1, #big do
small[i] = 0
local to_bits
bit_not = function(n)
local tbl = to_bits(n)
local size = math.max(#tbl, 32)
for i = 1, size do
if(tbl[i] == 1) then
tbl[i] = 0
tbl[i] = 1
return tbl2number(tbl)
to_bits = function (n)
if(n < 0) then
return to_bits(bit_not(math.abs(n)) + 1)
local tbl = {}
local cnt = 1
local last
while n > 0 do
last = n % 2
tbl[cnt] = last
n = (n-last)/2
cnt = cnt + 1
return tbl
bit_or = function(m, n)
local tbl_m = to_bits(m)
local tbl_n = to_bits(n)
expand(tbl_m, tbl_n)
local tbl = {}
for i = 1, #tbl_m do
if(tbl_m[i]== 0 and tbl_n[i] == 0) then
tbl[i] = 0
tbl[i] = 1
bit_and = function(m, n)
local tbl = {}
if(tbl_m[i]== 0 or tbl_n[i] == 0) then
tbl[i] = 0
tbl[i] = 1
bit_xor = function(m, n)
local tbl = {}
if(tbl_m[i] ~= tbl_n[i]) then
tbl[i] = 1
tbl[i] = 0
bit_rshift = function(n, bits)
local high_bit = 0
if(n < 0) then
n = bit_not(math.abs(n)) + 1
high_bit = 0x80000000
local floor = math.floor
for i=1, bits do
n = n/2
n = bit_or(floor(n), high_bit)
return floor(n)
bit_lshift = function(n, bits)
if(n < 0) then
for i=1, bits do
n = n*2
return bit_and(n, 0xFFFFFFFF)
local function lei2str(i)
local f=function (s) return char( bit_and( bit_rshift(i, s), 255)) end
return f(0)..f(8)..f(16)..f(24)
local function str2bei(s)
local v=0
for i=1, #s do
v = v * 256 + byte(s, i)
return v
local function str2lei(s)
local v=0
for i = #s,1,-1 do
v = v*256 + byte(s, i)
return v
local function cut_le_str(s,...)
local o, r = 1, {}
local args = {...}
for i=1, #args do
table.insert(r, str2lei(sub(s, o, o + args[i] - 1)))
o = o + args[i]
return r
local swap = function (w) return str2bei(lei2str(w)) end
local function hex2binaryaux(hexval)
return char(tonumber(hexval, 16))
local function hex2binary(hex)
local result, _ = hex:gsub('..', hex2binaryaux)
return result
local CONSTS = {
0xd76aa478, 0xe8c7b756, 0x242070db, 0xc1bdceee,
0xf57c0faf, 0x4787c62a, 0xa8304613, 0xfd469501,
0x698098d8, 0x8b44f7af, 0xffff5bb1, 0x895cd7be,
0x6b901122, 0xfd987193, 0xa679438e, 0x49b40821,
0xf61e2562, 0xc040b340, 0x265e5a51, 0xe9b6c7aa,
0xd62f105d, 0x02441453, 0xd8a1e681, 0xe7d3fbc8,
0x21e1cde6, 0xc33707d6, 0xf4d50d87, 0x455a14ed,
0xa9e3e905, 0xfcefa3f8, 0x676f02d9, 0x8d2a4c8a,
0xfffa3942, 0x8771f681, 0x6d9d6122, 0xfde5380c,
0xa4beea44, 0x4bdecfa9, 0xf6bb4b60, 0xbebfbc70,
0x289b7ec6, 0xeaa127fa, 0xd4ef3085, 0x04881d05,
0xd9d4d039, 0xe6db99e5, 0x1fa27cf8, 0xc4ac5665,
0xf4292244, 0x432aff97, 0xab9423a7, 0xfc93a039,
0x655b59c3, 0x8f0ccc92, 0xffeff47d, 0x85845dd1,
0x6fa87e4f, 0xfe2ce6e0, 0xa3014314, 0x4e0811a1,
0xf7537e82, 0xbd3af235, 0x2ad7d2bb, 0xeb86d391,
0x67452301, 0xefcdab89, 0x98badcfe, 0x10325476
local f=function (x,y,z) return bit_or(bit_and(x,y),bit_and(-x-1,z)) end
local g=function (x,y,z) return bit_or(bit_and(x,z),bit_and(y,-z-1)) end
local h=function (x,y,z) return bit_xor(x,bit_xor(y,z)) end
local i=function (x,y,z) return bit_xor(y,bit_or(x,-z-1)) end
local z=function (f,a,b,c,d,x,s,ac)
a=bit_and(a+f(b,c,d)+x+ac,0xFFFFFFFF)
return bit_or(bit_lshift(bit_and(a,bit_rshift(0xFFFFFFFF,s)),s),bit_rshift(a,32-s))+b
local function transform(A,B,C,D,X)
local a,b,c,d=A,B,C,D
local t=CONSTS
a=z(f,a,b,c,d,X[ 0], 7,t[ 1])
d=z(f,d,a,b,c,X[ 1],12,t[ 2])
c=z(f,c,d,a,b,X[ 2],17,t[ 3])
b=z(f,b,c,d,a,X[ 3],22,t[ 4])
a=z(f,a,b,c,d,X[ 4], 7,t[ 5])
d=z(f,d,a,b,c,X[ 5],12,t[ 6])
c=z(f,c,d,a,b,X[ 6],17,t[ 7])
b=z(f,b,c,d,a,X[ 7],22,t[ 8])
a=z(f,a,b,c,d,X[ 8], 7,t[ 9])
d=z(f,d,a,b,c,X[ 9],12,t[10])
c=z(f,c,d,a,b,X[10],17,t[11])
b=z(f,b,c,d,a,X[11],22,t[12])
a=z(f,a,b,c,d,X[12], 7,t[13])
d=z(f,d,a,b,c,X[13],12,t[14])
c=z(f,c,d,a,b,X[14],17,t[15])
b=z(f,b,c,d,a,X[15],22,t[16])
a=z(g,a,b,c,d,X[ 1], 5,t[17])
d=z(g,d,a,b,c,X[ 6], 9,t[18])
c=z(g,c,d,a,b,X[11],14,t[19])
b=z(g,b,c,d,a,X[ 0],20,t[20])
a=z(g,a,b,c,d,X[ 5], 5,t[21])
d=z(g,d,a,b,c,X[10], 9,t[22])
c=z(g,c,d,a,b,X[15],14,t[23])
b=z(g,b,c,d,a,X[ 4],20,t[24])
a=z(g,a,b,c,d,X[ 9], 5,t[25])
d=z(g,d,a,b,c,X[14], 9,t[26])
c=z(g,c,d,a,b,X[ 3],14,t[27])
b=z(g,b,c,d,a,X[ 8],20,t[28])
a=z(g,a,b,c,d,X[13], 5,t[29])
d=z(g,d,a,b,c,X[ 2], 9,t[30])
c=z(g,c,d,a,b,X[ 7],14,t[31])
b=z(g,b,c,d,a,X[12],20,t[32])
a=z(h,a,b,c,d,X[ 5], 4,t[33])
d=z(h,d,a,b,c,X[ 8],11,t[34])
c=z(h,c,d,a,b,X[11],16,t[35])
b=z(h,b,c,d,a,X[14],23,t[36])
a=z(h,a,b,c,d,X[ 1], 4,t[37])
d=z(h,d,a,b,c,X[ 4],11,t[38])
c=z(h,c,d,a,b,X[ 7],16,t[39])
b=z(h,b,c,d,a,X[10],23,t[40])
a=z(h,a,b,c,d,X[13], 4,t[41])
d=z(h,d,a,b,c,X[ 0],11,t[42])
c=z(h,c,d,a,b,X[ 3],16,t[43])
b=z(h,b,c,d,a,X[ 6],23,t[44])
a=z(h,a,b,c,d,X[ 9], 4,t[45])
d=z(h,d,a,b,c,X[12],11,t[46])
c=z(h,c,d,a,b,X[15],16,t[47])
b=z(h,b,c,d,a,X[ 2],23,t[48])
a=z(i,a,b,c,d,X[ 0], 6,t[49])
d=z(i,d,a,b,c,X[ 7],10,t[50])
c=z(i,c,d,a,b,X[14],15,t[51])
b=z(i,b,c,d,a,X[ 5],21,t[52])
a=z(i,a,b,c,d,X[12], 6,t[53])
d=z(i,d,a,b,c,X[ 3],10,t[54])
c=z(i,c,d,a,b,X[10],15,t[55])
b=z(i,b,c,d,a,X[ 1],21,t[56])
a=z(i,a,b,c,d,X[ 8], 6,t[57])
d=z(i,d,a,b,c,X[15],10,t[58])
c=z(i,c,d,a,b,X[ 6],15,t[59])
b=z(i,b,c,d,a,X[13],21,t[60])
a=z(i,a,b,c,d,X[ 4], 6,t[61])
d=z(i,d,a,b,c,X[11],10,t[62])
c=z(i,c,d,a,b,X[ 2],15,t[63])
b=z(i,b,c,d,a,X[ 9],21,t[64])
return A+a,B+b,C+c,D+d
function md5.sumhexa(s)
local msgLen = #s
local padLen = 56 - msgLen % 64
if msgLen % 64 > 56 then padLen = padLen + 64 end
if padLen == 0 then padLen = 64 end
s = s .. char(128) .. rep(char(0),padLen-1) .. lei2str(8*msgLen) .. lei2str(0)
assert(#s % 64 == 0)
local t = CONSTS
local a,b,c,d = t[65],t[66],t[67],t[68]
for i=1,#s,64 do
local X = cut_le_str(sub(s,i,i+63),4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4)
assert(#X == 16)
X[0] = table.remove(X,1)
a,b,c,d = transform(a,b,c,d,X)
return format("%08x%08x%08x%08x",swap(a),swap(b),swap(c),swap(d))
function md5.sum(s)
return hex2binary(md5.sumhexa(s))
do -- select MD5 library
local ok, mod = pcall(require, "crypto")
if ok then
local digest = (mod.evp or mod).digest
if digest then
md5sum = function(str) return digest("md5", str) end
if not md5sum then
local md5 = (type(mod) == "table") and mod or md5
md5sum = md5.sumhexa or md5.digest
if not md5sum then
ok = pcall(require, "digest") -- last because using globals
if ok and md5 then md5sum = md5.digest end
local s_http = require "socket.http"
local s_url = require "socket.url"
local ltn12 = require "ltn12"
local hash = function(...)
return md5sum(table.concat({...}, ":"))
local parse_header = function(h)
local r = {}
for k,v in (h .. ','):gmatch("(%w+)=(.-),") do
if v:sub(1, 1) == '"' then -- strip quotes
r[k:lower()] = v:sub(2, -2)
else r[k:lower()] = v end
return r
local make_digest_header = function(t)
local s = {}
local x
for i=1,#t do
x = t[i]
if x.unquote then
s[i] = x[1] .. '=' .. x[2]
s[i] = x[1] .. '="' .. x[2] .. '"'
return "Digest " .. table.concat(s, ', ')
local hcopy = function(t)
local r = {}
for k,v in pairs(t) do r[k] = v end
return r
local _request = function(t)
if not t.url then error("missing URL") end
local url = s_url.parse(t.url)
local user, password = url.user, url.password
if not (user and password) then
error("missing credentials in URL")
url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil
t.url = s_url.build(url)
local ghost_source
if t.source then
local ghost_chunks = {}
local ghost_capture = function(x)
if x then ghost_chunks[#ghost_chunks+1] = x end
return x
local ghost_i = 0
ghost_source = function()
ghost_i = ghost_i+1
return ghost_chunks[ghost_i]
t.source = ltn12.source.chain(t.source, ghost_capture)
local b, c, h = s_http.request(t)
if (c == 401) and h["www-authenticate"] then
local ht = parse_header(h["www-authenticate"])
assert(ht.realm and ht.nonce and ht.opaque)
if ht.qop ~= "auth" then
return nil, string.format("unsupported qop (%s)", tostring(ht.qop))
if ht.algorithm and (ht.algorithm:lower() ~= "md5") then
return nil, string.format("unsupported algo (%s)", tostring(ht.algorithm))
local nc, cnonce = "00000001", string.format("%08x", os.time())
local uri = s_url.build{path = url.path, query = url.query}
local method = t.method or "GET"
local response = hash(
hash(user, ht.realm, password),
ht.nonce,
nc,
cnonce,
"auth",
hash(method, uri)
t.headers = t.headers or {}
t.headers.authorization = make_digest_header{
{"username", user},
{"realm", ht.realm},
{"nonce", ht.nonce},
{"uri", uri},
{"cnonce", cnonce},
{"nc", nc, unquote=true},
{"qop", "auth"},
{"algorithm", "MD5"},
{"response", response},
{"opaque", ht.opaque},
if not t.headers.cookie and h["set-cookie"] then
local cookie = (h["set-cookie"] .. ";"):match("(.-=.-)[;,]")
if cookie then
t.headers.cookie = "$Version: 0; " .. cookie .. ";"
if t.source then t.source = ghost_source end
return b, c, h
else return b, c, h end
local request = function(x)
local _t = type(x)
if _t == "table" then
return _request(hcopy(x))
elseif _t == "string" then
local r = {}
local _, c, h = _request{url = x, sink = ltn12.sink.table(r)}
return table.concat(r), c, h
else error(string.format("unexpected type %s", _t)) end
return {
request = request,
