Threads: 9
Hello everybody,
I would like to know if there is a way to write object to logic machine through e mail. So i want from logic machine to receive mail????
I dont know if this is possible,
Thank you in advance
Threads: 41
What is the use case for that? You can use remote services (HTTP) but this will require port forwarding and is less secure. Best approach is to use MQTT.
Threads: 21
If you use Mosaic then you can have as many cloud users you want. All of them will be able to login if you gave them permission.
Threads: 6
There are a lot of ways to do this, you can use cloud app with users like Daniel suggested, you can use remote services, you can use MQTT, and many other approaches, but i think i would use SMS for this, add a dongle, add the phonenumbers who are allowed to send SMS to the device and make a handler on a received string.
So sending a SMS with text "Get temp serverroom" will result in a SMS response "I't's now 25 Degrees"
Threads: 14
Or you send a specific group address using the remote protocol to the controller that triggers a script that will send you the information you like by email, rss feed or push notification.
