Dimming time
Threads: 2
Quote:I am working with DAC8 device (analog output 0-10v). There is no dimming time setting on ETS.I want when set the value from 0 to 100, it will increase slowly in about 6s. As a newbie, I don't know how to be like that. Can anyone help me with this? An example.
Threads: 41
Are you sure you cannot set transition time in ETS?
For dimming via a script see this example: https://forum.logicmachine.net/showthrea...298#pid298
Threads: 2
04.02.2020, 10:25
(This post was last modified: 04.02.2020, 10:27 by Ntn.)
(04.02.2020, 09:25)admin Wrote: Are you sure you cannot set transition time in ETS?
For dimming via a script see this example: https://forum.logicmachine.net/showthrea...298#pid298 This is the parameter of the device I mentioned. I will see the example and try it
