Threads: 1
08.04.2016, 15:51
(This post was last modified: 08.04.2016, 15:52 by kbyberg.)
Hello.
For connecting dali ballasts to LM4 i've tried both Wago 787-1007 and Helvar digidim 402 power supplies. Is it just Tridonic PS2 that is compatible? Or should Helvar digidim 402 be able to fix it?
I read the question in FAQ's, and for me it is not entirely clear what functions i need to look for when i choose power supply. Is there any specifications of what i should look for?
Threads: 41
I'm not sure about Helvar, but Wago 787-1007 is a power supply for Wago DALI master. It is just a plain power supply that does not have the required components to allow DALI communication. We recommend Tridonic PS2 because we've done a lot of tests with it, but it does not mean that it is the only power supply that will work with LogicMachine.
Threads: 14
Hello Kbyberg,
we are succesfully using Helvar Digidim 402 for some time already.
Threads: 1
Okey, thank you.
I've connected it like the diagram in the manual for LM4, but still i can't find any devices when i'm scanning in the configurator. I use the internal gateway.
At this time i have only connected one ballast. Are there any restrictions in terms of minimum number of ballasts ?
Threads: 14
No, there are not. It should work fine also with only one ballast. Check the wiring, you should only connect DA+ and DA-, not SC connector.
