Threads: 5
I am trying to use Mosaic to dim my spotlights.
Everytime I try I can only get the lights to turn On or Off.
What type of Dimmer Object should I use?
In ETS it looks like a 3-bit control 3.007 but even if I use that object nothing changes.
I am using ABB Dali and not the one in my LM5.
Thx!
/Adam
Threads: 21
You should use 1 byte as it is in the widget. It is much easier to do it via slider. The one bit is to turn it ON/OFF while pressing the icon inside slider button.
Threads: 5
06.11.2020, 19:30
(This post was last modified: 06.11.2020, 19:33 by kenjirosama.)
Thank you very much for your quick respons!!
Works like a charm!!
Many thanks!!!
Threads: 0
Probably I do something wrongly but my KNX dimming devices work with 3-bit control 3.007 only. How to control them from Mosaic widgets?
Thank you.
Vaclav
Threads: 21
I never heard about such dimmer, which one is ti?
Threads: 21
This is what I meant above to use absolute dimming value. It is much more convenient and faster way of setting desired value instead of the step commands. At this moment of time I see no way to make it working properly in Mosaic. I will add to our development list demand for such widget but right now I would recommend you to use absolute dimming and a slider.
Threads: 0
I have in my ETS project brightness value signed like "STATUS" object - it didn't occur to me send there some value.... Stupid mistake.
Surely for Mosaic this is suffitient solution. 3-bit control 3.007 (dimming) is usable e.g. for full control of dimmable light by one wall push button only.
Sorry and thank you.
